Question about Dryers
Where can i buy a replacement part - solectron
Had the same problem with constant flashing lights was ok for a while but now the machine has stopped responding completely wont turn off have to unplug it to shut it off. Cleaned the filters but this didnt solve the problem. after further investigation I think i need a new part so my question is .....Where can i buy a replacement part - solectron 215009149.00 for my hotpoint aquarius wd440 washer/dryer ?
    President:
  • 1,922 Answers
Appliance parts pros web-site
Posted on Sep 10, 2009
Lid light flashing
OK have you tried unplugging the machine for 15 minutes and then re-plug in? This will reset it. If it still does this then the switch (little hole with white rubber depression on side where lid closes) is bad and needs to be replaced. It is a safety warning indicator telling you the machine is not Locked! It is annoying for a reason cause you can get hurt!
Jan 16, 2014 | Kenmore Washing Machines
Machine starts then program end light flashes constantly and has done nothing?
I had similar problem and Eventually replaced motor brushes which solved the problem
Feb 26, 2012 | Hotpoint WMA11 Front Load Washer
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a hotpoint aquarius WF321 and all the lights on the control panel are constantly flashing which means I can't even turn it off or do anything with the machine. On the odd occasion that it does stop...
i too have the same problem, i am going to buy a new PCB.
which is the electronic circuit board. about 75 quid.
cheaper than a new machine if it works
Dec 04, 2010 | Hotpoint Washing Machines
When switching the washing machine on all the lights are constantly flashing and they don't stop which stops me using the machine
If the dis[play lights are flashing and you are unable to set and cycles than it could be causes by a number of things. It will need to be properly diagnosed by a technician. It could be caused by a faulty board to a clogged drain or maybe even a faulty water inlet. But will require expertise.Hope this helps
Thanks
Dec 02, 2009 | Hotpoint Washing Machines
The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Nov 01, 2007 | Washing Machines
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
Dryers Logo
239 people viewed this question
Top Dryers Experts
