Carrier Comfort Zone II Smart Control in one zone frequently cycles unit (every 20-30 minutes) even when temperature in the room does not change significantly and the indicated thermostat temperature does not change at all (stays on 77 for example). Shouldn't the thermostat temperature change at least a degree or two in order for it to turn the unit on or off?? Is there a way to adjust the sensitivity of these controls?
  • 22 Answers
Sounds like your zone control tstat needs calabrated or maybe replaced,in owners manual there should be a section on calibration if not you may have to replace it
Posted on Sep 15, 2009
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Feb 16, 2018 | Carrier Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
Jul 15, 2017 | Heating & Cooling
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
Our Carrier Comfort Zone II thermostat, which has 2 zone readouts, currently shows a temperature of 00, as in zero zero, on one zone. That is the main zone for our home. Zone 2, for spare bedrooms, etc....
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Sep 25, 2010 | Heating & Cooling
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
We have the same problem, was hit with lightning and came up E1
You didn't get a Carrier tech. Carrier technicians only work on commercial equipment. Residential applicaitions, installation and service of Carrier residential units are done by dealers. They are not carrier owned but get buy the product at discount get training and get to show our logo. You can't fix the boards, they have to be replaced. It sounds like you have a Gen II VVT system. You can get the part via Totaline stores or a distributor. You will need to know how to readdress the other controllers to operate correctly. Use WWW.Carrier.com.
Aug 03, 2009 | Carrier 38CKC060 Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Heating & Cooling Logo
504 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
