Question about Texas Instruments TI-84 Plus Calculator
How do i change the contrast on my screen it has gone dark
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press and release the "2ND" key. Then press and hold either the up- or down-arrow key. Up-arrow darkens the screen, down-arrow lightens it.
Posted on Jan 17, 2010
How to adjust contrast
Are you asking because the screen has gone dark?Darkness is a backlight issue,can be the screen backlight,inverter or the cable itself causing it.Screen too bright can be adjusted via personalization or often keyboard shortcuts that have what looks like a sun symbol on them,the left key darkens when pressed and the right brightens
Aug 06, 2014 | HEWLETT-PACKARD HP EliteBook Notebook
I have sound but no picture
Picture tube gone out or someone darkened the screen by changing the light and dark screen main menu will have contrast or similar to bring back into picture
Aug 09, 2013 | Televison & Video
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
My screen is completely dark
It might be enlightening for me to know under what circumstances this eclipse happened. If that happened after a battery replacement the screen contrast has changed.
To restore the screen to its usable self, you should adjust screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD [DownArrow] to lighten screen.
  3. Release the [DownArrow] when contrast is adequate.
Feb 24, 2010 | Texas Instruments TI-84 Plus Calculator
The screen has gone dark on my Partner PT5500, where can I
backlight is not available seprately, try to adjust the brightness and contrast and do the reset on monitor,
Feb 09, 2010 | Partner Tech PT-5500 PC Desktop
The screen is too dark to read
See if there is a contrast adjustment somewhere on the laptop first, if not then its a possibility your back light has gone and needs replacing.
Jan 19, 2010 | Acer Aspire 3000 Notebook
My calculator works fine but recently when I use it the screen is very light. I already have it on maximum darkness and sometimes it works but occasionally the screen flickers?
When screen is at maximum darkness you see almost nothing.
Here how you change screen contrast (just in case another readed does not know how to do it).
To increase contrast:
1. Press [2nd] key then release it
2.Press [UpArrow] key then release it.
3. Repeated steps 1 and 2 in sequence, until contrast is dork to your taste.
To decrease contrast:
Follow the algorithm (a very big word for procedure) above substituting [DownArrow] for [UpArrow].
Hope it helps.
Jul 17, 2009 | Texas Instruments TI-83 Plus Calculator
Real dark screen on Toshiba A135-s4437
First I would check to make sure that the contrast/brightness buttons on the laptop weren't accidentally changed, making the screen dark. Also, try with and without the battery and power supply. Otherwise, unless it is actually the screen that is defective, it is usually a power converter replacement, which is a small circuit board, usually under the plastic cover directly under the monitor, which supplies power to the monitor. You may want to take it to a shop as they can isolate the issue easier.....
Mar 10, 2009 | Toshiba Satellite A135-S4437...
Dark screen
contrast or brightness problem.
Dec 08, 2007 | Toshiba Satellite A20 Satellite A25 Series...
Texas Instruments TI-84 Plus Calculator Logo
218 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
