Beko WMA765S fills, stops, then drains and stops
My beko WMA765S starts cycle as normal then after about 2 mins stops, it then does nothing for approx 10 mins and then skips immediately to Drain (2 min cycle) it drains and cycle ends, but the door doesn't unlock. I have checked the filter, it is clear and turning freely.
What should I try next?
    Sergeant:
  • 193 Answers
I would think about replaceing the timer
Posted on Sep 09, 2009
Beko WMB714422 .... washing cycle stops after 5 mins of the cycle and shows 'end'. Cant get it to do a full cycle. Any ideas ?
This is most likely an issue with the motor, causing confusion to the electronics, sometimes you can replace the motor and remedy the issue but I have had a couple of occasions with Beko machines where the motor fault caused damage to the control board
Jun 12, 2016 | Beko Washing Machines
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
How do you reset a beko washing machine??
It's actually pretty easy. Try this: press and hold the start button in for 5 seconds.drain pump will start up.let it complete its routine (takes 2 mins or so).now the machine has reset.select program as normal and retry
Hope this helps
Dec 26, 2010 | Washing Machines
Washer stop before completely filled with water.
beko washing machine when turn it on it trips
Dec 12, 2009 | Kenmore Washing Machines
Beko wma765s washer error code 1L and flashing 1200 spin light washer completed wash but when went to load up again refused to start and 1200 spi n light flashing as well as flashing 1L in time remaining...
Main board fault.engineer says not worth fixing.sourced board and replaced myself cost me £50 but have seen it priced at £63 and £86 .got mine by phoning Beko spares. took 10 days tho.as not in stock
May 17, 2009 | Washing Machines
Push start button fills with 2in of water then does nothing
hi there........this fault is usually associated with a faulty flow meter....situated on the lower left hand side of the apliance and is only accessible on removal of the left hand cabinet panel
regards Sir Galahad
Apr 15, 2009 | Beko 24 in. D3421F Free-standing...
Beko washing machine fills with water when not in use!!
hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
425 people viewed this question
Top Washing Machines Experts
