Question about Toshiba 1370 Black and White Copier
My toshiba is showing that it's out of toner and won't copy. I've had a look and the toner cartridge is still pretty full so any help would be great!!!
  • Nike Merritt May 11, 2010
    I am not familiar with this machine but most of toshiba cartridges have an external gear that drive internal stirrers. Take out the toner, turn the gear and see if the toner comes out, if not the connection between this gear and the internal drives is broken and the cartridge is toast. try this
  • 4 Answers
Hi when the copiers shows that need toner it is becouse there is no toner in the mix of developer, this is caused by a wrong toner in the machine, check that the toner is the one the machine use there are few copiers like lanier that seems to use the same cartridge but change the gear that turns the toner in the machine, move manually the gear in the cartridge by looking that the toner actually it is ok, activate the motor that moves the toner cartridge and check thatis is moving, also check the gears on the developing unit becouse if any of them dont move the toner never get the sensor of the developer unit and shows the signal of lack of toner
jesus contreras ortega
Posted on Sep 12, 2009
How can I solve Toshiba e studio 257 photocopier toner problem?
Try turning the main power switch off or disconnect the power, wait 20 seconds then turn back on again. This should reset the toner.
Aug 29, 2016 | Toshiba Office Equipment & Supplies
Toshiba E-Studio 232 PhotoCopy Too Light, Why?
one simple way that may help you out , take out toner cartridge shake it to equalize toner powder , try it may work
Jul 25, 2014 | Toshiba E-Studio 232 Copier, 232 Digital...
When i start my toshiba e-studio 206 show Ink blinking icon
Please check the toner cartridge is actually emptied, if so replace it with a new one, if not, clean the contact of the chip, that locates in the back of the cartridge. You must use the genuine Toshiba toner cartridge, that has a chip circuit board on the back, those 3rd party cartridge created lots of problems, results lost of time and money that you would not like to hear.
Oct 29, 2013 | Toshiba E-Studio 206L Copy Machine
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
Screen reads no cartridge when there is a full cartridge in the printer
This is a pretty common item, usually for HP printers however I've also seen this with non-HP printers. They REALLY want you to use genuine HP or Dell ink/toner in their printers since they make lots of money on consumables. That being the case, there is a chip on most original (OEM) toner cartridges that tells the printer that its a genuine cartridge. If you purchase aftermarket/remanufactured/3rd party toner to save a few dollars, they frequently don't have these chips, however other than that they work just fine.
If you have purchased a Staples/Office Max or some other non Dell branded toner, that's likely what happened. My suggestion is to live with this minor annoyance and just wait until the print begins to get lighter in color. THAT will be your indication that its about time to change the toner.
If you get this same issue with a new Dell branded toner, then you may want to try to find this chip and use a pencil eraser to carefully clean the electrical contacts on the toner cartridge. That may help the printer read the cartridge chip easier.
Hope this helps! Best of luck!
Jun 21, 2011 | Dell 1600n All-In-One Laser Printer
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Toshiba 1370 Black and White Copier Logo
255 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
