Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint side by side csx22grbk serial vz247504
Frost on back of freezer compartment and refrigerator shows temperature of 50 degrees. Fan on compressor works and fan behind automatic ice maker works.
    Problem Solver:
  • 17 Answers
Chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
Posted on Dec 10, 2007
My ice maker not making enough ice . I have already check the water. thank you
When an icemaker slows production, the problem is not the icemaker at all but the temps in the freezer warming up because of an airflow problem either in the freezer compartment evaporator coils or underneath the unit that being the condenser coils. (Fan not working or lint blockage)
Airflow problems in the freezer compartment are caused by the fan or the automatic defrost system not functioning properly so yu end up with an ice block / lots of frost in the freezer compartment on the back wall of the compartment.
Check for ice or large amounts of frost in the freezer compartment. If you note ice / excessive frost, unplug the unit, empty the freezer compartment and do a manual defrost by directing an external fan into the compartment for just over 2 hours. This will ensure the evaporator coils and the freezer compartment drain have thawed. While the manual defrost is in progress remove the rear fiberboard cover from the compressor access and check / clean the condensor coils and fan area.
After 2 hours clean up the excess water.. reassemble the rear cover and return the unit to NORMAL service. It should start making lots of ice in 4 to 6 hours. Here is the kicker... if there is an auomatic defrosting problem your icemaker will after 2 - 3 days again slow ice producion and ice will build up in the evaporator area. You will have to keep repeating the manual defrosting process every 3 to 4 days until the automatic defrost system is repaired.
There are 3 main components of the Automatic defrost system:
1. Defrost control
2. Defrost heater
3. Defrost thermostat or depending on type thermistor
Most of the time the problem is either the defrost control or the heater that fails and the unit stops defrosting.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LSC26905TT/3204/0165000
Thanks for choosing FixYa,
Kelly
Jun 23, 2011 | LG LSC26905TT Side by Side Refrigerator
The freezer isn't cool enough and the refrigerator temperature goes up when we put stuffs.
I would first look under the ice box for signs of air restrictions. Clean out the bottom and make sure the fan and compressor is working. Inside the ice box listen to see if the fan is running in there. If that is fine I would look for signs of frost on the back wall of the freezer. If frost is present then ice is on the coils and you have a defrost problem. Their are 2 basic circuits in an ice box. Compressor run AND Defrost run. Compressor run circuit is anywhere from 8 to 12 hours depending on manufacturer. Defrost is 21 minutes. On new fangled electronic ice boxs the brain decides when defrost is needed using inputs from sensors, compressor run time, and how many times the ice box is opened and closed. But the new fangled ice boxs still have a defrost heater and thermostat like any ice box with automatic defrost has. Why do we need a thermostat? The heater is very powerful. It could easily destroy the ice box. It takes only moments to elevate the crawlspace inside the evaporation compartment to 50 degrees F. This keeps any frost that could turn into air flow blocking ice at bay.
Remember the defrost time is 21 minutes. If that heater was left on for 21 minutes it would not be purty. The termination thermostat is recommended to be replaced if it goes bad or whenever the heater is replaced. I say replace all 3 things in the circuit and be done with it. But who these days can afford that? If you suspect a defrost problem just unplug the ice box for a day or 2. If the ice box goes back to performing ok then you can suspect you indeed have a defrost problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 21, 2011 | Refrigerators
The refrigerator side is only getting down to 50 degrees. the freezer is down to 0 degree. unit is about 2 yrs. old.
There is likely a problem with the defrost circuit or fan (but could be a low freon charge or other problem). The freezer compartment has the cooling coil with defrost heater and a fan that pulls cold air from the freezer into the fresh food compartment, based on the setting of the thermostat in the fresh food compartment. Before you dig into that, you should vacuum the condensor coil to remove dirt and dust that always collects on it. It that solves it - you're done. Otherwise, continue.
When the defrost heater fails, the area that the coil is in turns into a solid block of frost and ice. It becomes impossible for air to be drawn across the cold coil, cooled and blown into the fresh food compartment. The result is a rising temperature in the fresh food compartment - and eventually in the freezer section, too. Since the fresh food compartment contains the thermostat and the temperature never gets low enough to satisfy it - the compressor runs non-stop. That is, until the defrost timer kicks in to shut it off for 20 minutes or so.
The first thing to do is to manually defrost the freezer by accessing the cooling coil after emptying the contents of the freezer. This can be a pain in the neck to remove racks, shelves, ice maker, etc. to get to the back wall of the freezer, behind which the coil is protected. If you expose the cooling coil and it is encased in frost and ice it is a problem with the defrost circuit. If it is not - the fan is suspect. If the fan spins, check for a blocked path between the fan and the fresh food compartment.
If it is a defrost circuit problem, you'll need to check voltages and continuity on the defrost terminator & timer and defrost heating element, fans, etc. after completely thawing the ice & frost. This job isn't a good first time DIY job due to the danger of freezing skin, etc. due to possible exposure to freon in the system and the tight spaces you'll be working in with live voltages. You might want to call a pro after you've defrosted or put up another fixya request if you decide to dig in on your own and need specific help with procedures, locating parts, wiring diagrams, etc.
I hope this was a good starting point to help you decide whether to go forward or not on your own. Good luck!
Aug 09, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator warm freezer too cold
If you have already adjusted the controls for temperatures in both compartments and allowed 12 - 24 hours to stabilize and the trend is continuing, there may be a problem with the fans that move the cold air from the freezer to the fresh food compartment. The fridge may also start allowing temperatures to rise in the freezer soon, too.
All of these problems originate in the freezer compartment, where the cooling is done. Behind the back wall; inside the freezer - lies the cooling coils, defrost heater, circulating fan(s) and defrost terminator sensor. Unplug the fridge. Empty the contents of the freezer, remove the ice maker assembly and the back wall plate and you should see these components. If it looks like a large block of snow and ice, the problem is with the defrost circuit components. If clear with a minimal amount of frost, the warm fridge is the result of blocked or limited airflow from this area to the fresh food compartment - likely a failed circulating fan. Plug the fridge back in and check to see if the fan is running - since the fridge is warm, it should be running. The fan or the thermostat will probably need replacing if it is not.
If icing or frost is the problem, you'll need to isolate and replace one or more of the following: defrost heater, defrost terminator or defrost timer. The last two are the usual suspects for this type of failure - but the heating element can fail too. Many times, the defrost timer is accessible from the front of the fridge, behind the kick plate below the freezer door on the right side. Other times it is located in or near the temperature control area.
Jun 18, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Condenser fan always runs so freezer won't maintain temps. What makes the condenser fan run? How can I get that fan to cycle?
Good day,
The fan motor runs when the thermostat asks it to.
If the machine is not at the proper temperature, the fan will run 24/7.
You have a cooling problem with the machine.
here are some areas to check.
1. The fan motor in the freezer compartment. It is behind the rear panel. You should be able to hear it running when you open the freezer door.
2. The defrost system has failed. Once again, open the freezer door, if you see frost built up on the rear panel, Either, the defrost timer, defrost thermostat, or main heater has failed.
3. The compressor is bad, or the start components mounted on the side of the compressor have failed.
4. Refrigerent has leaked out, or the system has an internal restriction.
The last 2 items are best left to a trained repair technician.
Dec 05, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator failed keeping food cold, ice maker stopped working
i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Nov 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Frigidaire FRT 22INLHW3 Top Freezer Please help?Freezer works fine, the automatic ice maker works fine but the refrigerator temperature stays at about 50 degrees and up and gets warm, I have cleaned the...
hi thanks for the question the freezer will work kind off ok, even if the fan in the freezer is . not working . check that check for frost on the freezer wall
Sep 29, 2008 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Sep 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
404 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
