Question about Magic Chef MCBR440 Compact Refrigerator
I have magic chef mini refrigrater freezer not freezing and getting water in tray under freezer part. what can I do?
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Water appears on the floor outside the fridge. I have a side by side fridge freezer, Magic Chef
There's a tray under the refrigerator that catches the water dripping down when your auto-defrost cycle runs. Usually this water evaporates before the tray overfills. Either you don't have enough air flow around the refrigerator for the water to evaporate, or the tray may have developed a leak.
Oct 10, 2014 | Refrigerators
QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
Have a magic chef, top freezer, one size bigger than dorm size. freezer doesn't freeze and continually produces water that freezes all over bottom of freezer. what to do?
There are three chances for not getting freeze. Defrost activate quickly, due to: 1. Thermostat malfunction- Replace it. Thermostat setting. - Must be -5 degree or less than that. 2. Defrost timer for malfunction. If so, replace it. 3. Freezer heater malfunction.- Replace it.3. System chocked or short of gas. Check with run amps.
Solution: If system chocked, release all gas and replace filter drier. Flush out the system, vacuum and recharge gas. If short of gas, leak test and arrest it. Vacuum and do gas charging. Thanks.
Jan 31, 2011 | Magic Chef CTB2121AR Top Freezer...
I have a Magic Chef refrigerator and water is dropping into the vegetables section at the bottom of the fridge. What could be the cause? Thanks a lot!
There are only two reasons. 1. Water hose may be worn our or dust blocked. 2. Bottom tray of the freezer may be cracked.
Dec 08, 2010 | Magic Chef Refrigerators
How do I clean the tray under the fridge, it has an awful order but I cant remove the tray help?
Gently push down on the front corners and pull out. Wash with a tablespoon of bleach mixed in a quart of hot water to kill bacteria.
Nov 17, 2010 | Magic Chef CTF2125 Top Freezer...
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
Magic Chef MCCF5W do not works. Fast freeze is working.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
Magic Chef MCBR440 Compact Refrigerator Logo
440 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
