Question about Whirlpool Refrigerators
I have a Kenmore refrigerator made by Whirlpool. Its Model # is 10657562790. S/N is SG2234335. Mfg. date is 05/1997. My water dispenser does not work after replacing ice maker/water dispenser inlet valve/solenoids. Does not sound like anything happens when I push the dispenser lever. Is there a micro switch that is acuated by the lever?
  • tmcenaney Sep 10, 2009
    I have not been able to remove the front cover (it has the switch membrane panel for the ice dispenser {cube/crushed} as well as the on/off switch for the light. Is there some trick to this. I am able to get one side loose enough to get a finger behind the cover, but it feels as though it's being held by something. Are there tabs at the top and bottom of this cover? Any hints on how to get this off easily?
  • 854 Answers
1. You should check the incoming solenoid valve probably is out or the something stuck at the filter strainer.
2. You my have air in the line. disconnect it and bleed off the air bubbles ..than hook it back up.
3. It might be a low water pressure problem either before the inlet valve or after the inlet valve. Disconnect it from the fridge, let it pour into a container or bucket and judge for yourself how it fast it comes out. If it pours out in a good steady stream and you've already replaced the filter, then it has to be the inlet valve.
Posted on Sep 10, 2009
  • 3,741 Answers
Depress the activator lever on the front of the refrigerator.
Its definately a low water pressure problem either before the inlet valve or after the inlet valve. Disconnect it from the fridge, let it pour into a container or bucket and judge for yourself how it fast it comes out. If it pours out in a good steady stream and you've already replaced the valve , then it has to be the inlet valve.other wise its filter.
to check if the lever is broken follow this instructions
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing.
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. 3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. 3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there.
thanks.
Posted on Sep 09, 2009
Can I view a manuel for Kenmore Refrigerator online?
If you have the model number, you can download the manual at searspartsdirect.com. However, it won't have the mfg date. User Manual Downloads
Oct 04, 2014 | Kenmore Refrigerators
Cubic feet of 1999 kenmore refrigerator model 70289990
How many cubic feet is my fridge ...Kenmore model # 106.70872990
Serial # EJ4814023
MFG date 11-99
Sep 15, 2013 | Kenmore Refrigerators
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
I have a refrigerator model #GD5PHAXMS10 icemaker that stopped working about two and a half weeks ago. At that time the water the water works dispenser worked like normal. Today the water dispenser...
The first thing to do if you already haven't is replace the filter,it's in the grill/kickplate below the freezer door. If you have relpaced filter,need to pull refrig from wall and check that their is good water pressure from house plumbing,if it is good the water valve the sends water to icemaker&door dispenser when water is called for is going to be the problem.The part # for that valve is 4389177 it could be purchased at your local appliance parts store on oline at;
apdepot.com
repairclinic.com
assuredparts.com
The filter BUT NOT the water valve could be purchased locally at Sears,Lowe's or Home Depot
I hope this helps you to diagnose your icemaker/dispenser
Gene
Aug 07, 2011 | Refrigerators
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Whirlpool refrigerator model ED22GW makes the ice but won't dispense, any ideas why?
if it has never dispensed ice,the mfg places a stopper in the dispeser during production. remove it. if the ice just jams up and wont come out, use non-stick cooking spray around the opening of the dispenser. they can jam up if you dont use them often enough and little droplets of water freeze up. either one of these should help, if not I have no idea whats going on and you should call the person who sold it to you.
Oct 06, 2010 | Whirlpool Refrigerators
DOES THE THIS FRIDGE MODEL #106.74912401 REQUIRE TO REPLACE WATER FILTER FOR FRONT DOOR WATER DISPENSE?? ITS A KENMORE ELITE
HI. When a filter has reached its filtering limit, it must be replaced. Once the filter has reached its filtering limits, it will not allow for proper water flow. This will affect the operating status of the dispenser. With that being said, there are other issues that will affect the dispensers abilities as well. These issues are a faulty water inlet valve assembly, and frozen inlet lines. If you are having issues with the dispenser, make sure you inspect these areas as well. Your filter should have an installation date on the label. check to see that it is not over a year old. if so, it should be replaced.
The filter is located behind the front lower grille work. The grille should have a cut out space for it to slide into.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
I have a Kenmore side-by-side refrigerator and there is no water coming thru the Dispenser. However it makes ice. The model # is 25355689408 Thanks brian
the water tube nside of the refrigerator is frozen up. take a hair drier and locate the roll o tubing and thaw it out.
Mar 07, 2009 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
