I cannot get wireless to work on my comouter. I can get the internet via cable from computer to wireless box. My laptop works ok on wireless. I changed my wireless router from netscape to Thompson speed touch 585 and since then I have not had wireless on my computer without the cable. When i load the disc that came with the router i get to the point were it searches for a way to connect but cannot find a way. My comuter runs on windows xp
  • 1,272 Answers
Follow the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to
Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
let me know if you need any further help.
Posted on Sep 09, 2009
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
When i install the router which is connected to a cable modem, using the setup cd i get an error message stating that the internet is not connected, the desktop pc which is connected via cable can access...
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Apr 29, 2010 | D-Link DIR-615 Wireless Router
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
There is no internet working with the Belkin G wireless Router
How do you have your connection set up? Normally, your modem connects to the router, and router to computers, this is how yours is set up? Since your router is wireless-capable, just make sure that your laptop has its wireless turned on and you have the router's "Wireless" set up, name (SSID) is done, security method chosen. I like WEP-PSK[TKIP] for its simplicity, keeping in mind that all logins to your network will need this passcode as well.
Nov 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
My laptop wont connect to the wireless internet
If your wireless can connect to your network but you can't access the internet than there is an easy fix that usually works. In most cases this is a configuration problem and not easy to track down. So, to bypass all the headache we are going to uninstall the adapter and let windows re-install it with fresh drivers. This will work better if you have the laptop connected to the internet via a ethernet cable but it's not required.
Go to control panel > System > Hardware > Device Manager > scroll down to network adapters > click on the plus sign and right click on the wireless adapter and select uninstall. Make sure the box marked remove drivers is UNCHECKED. We need to make sure the drivers are not deleted. Now, reboot the computer and let windows find the hardware...it will start the re-install and may even ask if it can search windows update to check for a fresh driver...click ok and let windows do its thing. reboot and when booted, try to connect to the internet.
Sep 15, 2009 | Computers & Internet
Wireless internet connection
You need to set up a new log in code
Jul 20, 2009 | Dell Inspiron B130 Notebook
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
