Question about Canon EOS-1Ds Mark II Digital Camera
Shutter freezes i think it is error 99 - past the warranty
    Brigadier General:
  • 4,090 Answers
Heres the answer to the dreaded 99 error
acquire a penscil withy an eraser on the end
remove lens and hold it mount down but at a height that you can rub the pins so that the swarf does not drop into the mechanism.
Do the same to the pins on the camera, also holding it face down also to stop the swarf getting into mechanism. Once they are cleaned off use a can of compressed air and blow out the lens and the camjera ( being carful not to blow too hard on/around the mirror
Remount the lens and ...happy days!
Please rate our help to keep the FREE service online++++Thanks for usimg FIXYA
Posted on Sep 09, 2009
Error 99 lens shutter
Probably this is caused by a bad shutter
. The 2nd curtain switch breaks off
Apr 25, 2013 | Canon EOS-D30 35mm SLR Camera
Error 99 message keeps popping up
Hi
I just read that the error 99 problem is a shutter failure and the shutter will have to be fixed. The cost is about $180.
see http://www.mcvr.com/canon_digital_rebel.htm?gclid=CJqG4cvc05oCFRMhnAodCHUA3Q#shutter
ERR99 (error 99) is an indication that there is a communication problem in the camera. It is most often an indication that the shutter needs to be replaced, but it can be the result of other problems. All digital cameras occasionally need to have the shutters replaced. In the days of film cameras, it was rare to wear out a shutter because the cost of film and developing limited the number of times the shutter was cycled. With all those ones and zeros being considered "free" in digital cameras, it is not uncommon to take several hundred or more photos in a day. Even with a live-expectancy of 50.000 to 100,000 cycles, the shutters in digital cameras do reach the end of their life and need to be replaced.
Shutter replacement (usually associated with error code "99"):
  • Replacing the shutter on the Digital Rebel series requires more disassembly than most other repairs.
  • The estimate for shutter replacement is $180 on all EOS Digital Rebel models (depending upon the overall condition of the camera).
  • ERR99 error codes are related to shutter or mirror operation and are usually associated with a defective shutter. Cameras that have had heavy use may have shutters that have reached life expectancy and need to be replaced.
May 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Codee error 99 ??
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
Hope this helps !!!
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
ERROR 99
if you have a DSLR and your'e getting this "error 99" it may be associated with the particular lens youre using. try turning off the camera and removing the battery, the lens, and the memory card. let it sit for half an hour. reinsert the battery only and depress the shutter button as if you were to take a normal picture. if error 99 occurs again, then the camera needs servicing. if it error 99 doesn't occur at this point, turn the camera off and install the memory card. format the memory card while it's in the camera and press the shutter button as if youw ere to take a normal picture again. if you see error 99, then the problem probably lies with the memory card. if it doesn't occur, turn off the camera and install the lens. again, power on the camera and press the shutter as if you are taking a normal picture. if the error occurs, then it's with the lens. try to clean the lens including the connection points both on the camera and the lens. if the error code still occurs, try different lens to narrow it down to which particular lens is giving the issue. if it happends with all the lens, then the camera needs to be serviced.
Sep 16, 2008 | Canon Cameras
Canon rebel xti digital camera error code 99
Error 99 is shutter error. Best solution is to replace it ASAP if the camera is still under warranty. We go through many replacement of shutters for many Digital Rebel series. There is no simple answer without replacing it to good shutter part. The problem will keep coming back. Out of warranty repair charges may run from $150 to $250 depending repair facility. -James. For further assistance by email, go to www.camerarepair.com
Aug 16, 2008 | Cameras
Canon rebel xti says cf card replace i have replaced same fault
Check with a magnifier and a flashlight the conditions of the CF memory reader pins. Usually this kind of cameras have the common problem of have bent or broken the CF reader pins. This may caused the original CF error. If you tried to format a CF memory card, then the bent or broken pins may caused the Error 99. By the way, error 99 is applicable to a very open range of problems (lens contacts, faulty shutter, CF memory card access errors, etc). If is under warranty your camera, once you confirm the reason of the problem, send it to Canon for repair. If is out of warranty, you need somebody to repair it, which is not easy for the common person. If need help on repairing it, please contact the ID user Great_items_2004 at ebay. Regards and good luck.
Jul 08, 2008 | Cameras
Canon 20D error 99 shutter stuck
Exactly same problem, shutter clicks until battery removed. Power may be on or off.
Apr 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 Code on 5 month old Canon 40D
error 99 can be several things. Try the following. Check that the contacts on the lens housing are clean if not clean them with a swab of denatured alcohol available at walmart. also if there is extremely cold weather your shutter could be creating the error. Try using a blow dryer and on the warm setting warm up the camera with the lens off. Blow around the mirror area. I know it sounds silly but it has worked in the past. Good luck.
Feb 20, 2008 | Canon EOS 40D Digital Camera
Infamous error 99 (again!)
shutter mechanism of canon 300d lasts for around 5000 shots or less!! yes it is made of plastic materials thats why here in the philippines I am making my own metal replacement parts that lasts. Unfortunately, in your country you cant do anything but to replace it with same original replacement parts. avoid using faster shutter speed and continuous shots.
Nov 12, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS-1Ds Mark II Digital Camera Logo
164 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
