Question about 3Com Computers & Internet
Stuck at Acquiring network address
I feel your pain.... I am experiencing the same. I am installing a wireless usb adapter to my laptop and it says acquiring network address, then it keeps trying, last it disconnects. I read that it might be the encryption key that was entered. If it is not entered correctly, this is what happens. Another, is that it could be that you need to bridge your modem. If you go to the command prompt, start> run>cmd, then type the ipconfig and hit enter; if you get a 192.168.XXX then you will need to contact your ISP to inform them you need to bridge your modem. All this is done after you plug your ethernet cable directly into your laptop. This means that the ethernet cable is into the modem then into the computer ether port. If not connection, then you need to bridge.
All of this is what i read, but I haven't tried anything but the cmd. Unfortunately, my laptop doesn't have an ethernet port so there is no direct way to see if i need to have a bridge...? Anyway, hope this helps a little.
Good Luck!!!
  • 1,272 Answers
Follow the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Make sure that you have the correct security key for the wireles connection.
Let me know if you need any further help.
Posted on Sep 09, 2009
Acquiring network address xp
You must have at least the date right and the time otherwise you get this response. Set the time and date on your computer to solve this issue. Let me know if this works.
Dec 05, 2013 | Belkin (F5D7000) 802.11g/b Wireless...
Acquiring network address ip
This depends on the address you are looking for. The typical address for the adapter is as follows: IP 192.168.1.100 Sub mask 255.255.255.0 Default gateway 192.168.1.1
Oct 15, 2013 | TP-LINK TL-WN321G (812930011748) Wireless...
Just keeps saying acquiring network address
Go to Belkin : Support
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 22, 2010 | Belkin Play Wireless USB Adapter (F7D4101)
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Hung on connecting to router
Reinstall the computer operating system and then install the adapter drivers.
Nov 05, 2009 | Belkin Wireless-N USB 2.0 Adapter
Unit will not connect, getting acquiring network address.
Hi Houzeman Have you: re-started the computer         power-cycled the router, ie, unplugged unit and waited 10+ seconds, before re-connecting                 disabled the unit, then enabled it checked in Control Panel that the wireless card/ usb adaptor, is enabled; try disable/enable
before checking settings
re-input username and password
re-input security settings?
If you are using a separate modem and router, turn both off, then power-on the modem, before the router.  If you have ethernet access, and a Local Area Connection is available, use it to open a browser and type in 192.168.2.1 (assuming yours is a Belkin) and check your settings.
I use a Belkin, which is a good unit, but it can be cantankerous sometimes, dropping out, then coming back unexpectedly and without reason. Good luck NOEL
Mar 17, 2009 | Belkin Wireless-G Plus MIMO Router with...
if you are using the dell wireless utility to manage your card, then disable it, and manage your wireless adapter through the windows network connections. that way the wpa issue will be solved by windows xp wpa. i had a similar problem with my inspiron 1525 (dell wireless 1395)
Jun 09, 2008 | Computers & Internet
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
133 people viewed this question
Top 3Com Computers & Internet Experts
NBX_Tech
NBX_Tech
Level 1 Expert
steve morris
steve morris
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
