Question about ASUS P4S800D-X Motherboard
I start the PC
Warning !! the previous performance of overcolking is failded...press enter do restore to default settings
  • 3,153 Answers
Your BIOS has an option for optimal settings or failsafe
The message you got usually happens whe overclocking so reset the last item you changed to what it was before or use the default settimg from the bios
Posted on Sep 09, 2009
Dell studio 1537 repair computer dosnt work
WARNING: When you restore the computer to the default factory configuration, all data on the C drive is deleted. Before performing this procedure, you should back up your personal files.If your computer is running, Click Start > Restart
While the computer starts, press the F8 key, until the Advanced Boot Options menu appears.
Using the Down Arrow , select Repair Your Computer and press Enter.
Select your language
and click Next.
Log in as an Administrative user, and click OK.
Click Dell Factory Image Restore from the System Recovery Options.
From the Dell Factory Image Restore window, click Next.
Click the check box that says: Yes, reformat hard drive and restore software to factory condition.
Click Next. Wait while your computer is restored to the default factory configuration
Once the restoration has completed, Click Finish
Windows Vista is now installed on your Dell Studio, configured just as it was when you first received the Computer.
Hope that helps.
Dec 31, 2013 | Dell Studio 1537 Laptop
Unclock security code
Steps to perform Master Reset
All configuration settings will be set back to their factory defaults. Personal data and downloaded content, however, will not be lost.
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Phone Settings.
  4. Scroll to and select Reset Settings.
  5. Select Master Reset.
  6. Select Yes.
  7. Enter Security code, then press OK. The default security code is 0000.
Steps to perform Master Clear
All configuration settings will be set back to their factory defaults. Also, all personal data (including contacts) and downloaded content will be erased.
  5. Scroll to and select Master Clear.
  6. Select Phone.
  7. Select Yes.
  8. Enter Security code, then press OK. The default security code is 0000.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.
Dec 20, 2012 | LG Neon GT365 Cell Phone
How do I clear all information from a LG VX5500 Cell Phone before returning it.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. With the flip open, press the OK key [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Select Revert by pressing OK. A confirmation message is displayed briefly before the phone resets itself.
Steps to Restore Phone
This erases all user data and contact information entered in phone memory.
  6. Press 6 or Restore Phone.
  8. Enter lock code. The default lock code is the last 4 digits of your phone number.
Sep 14, 2011 | LG VX5500 Cell Phone
I want to restore my acer aspire 5741 to factory settings but when i go to restore it, a message comes up saying hard drive configuration is not set to the factory default. reboot aborted.
Before performing a restore operation, please check the BIOS settings. To activate the BIOS utility, press F2 during post.
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process.
3. Refer to onsreen instructions to perform system recovery.
Follow this steps.
Thank you for using FixYa.com
Jan 08, 2011 | Acer Aspire 5100 Notebook
I don't have my security key for my belkins router?
In order to rest your password or if you forgot it you need to reset the router.
  1. Locate the reset hole on the router. The button will be on the back or side of the router.
    See images below:
  1. Leave the router powered on.
  2. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  3. Remove the paperclip.
  4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default.
---------->>>>>>> OR:
Restoring the router to default using the web interface
Symptoms
You need to restore the factory defaults using the web interface. This may be because the router is not performing as expected or you wish to remove all previously configured settings.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  1. Click on "Restore Factory Defaults" in the left-hand column under the Utilities heading.
  2. Click on the "Restore Defaults" button.
  3. A warning box will open that says, "Warning all your settings will be lost, are you sure you want to do this?" Click OK.
  4. The router will begin the restoring process. Once the restore is complete, the router will reboot.
    Note: This may take several minutes.
Your router has successfully been restored to its factory settings.
Nov 07, 2010 | Computers & Internet
How to set my vaio back to factory default with no boot disks and recovery center doesnt work
The VGN-FW370J/H Computer is shipped with Recovery Partition which is present in the hidden partition of the Hard Drive.
If you do not have the Recovery Discs and the VAIO Recovery Center is not working, a recovery of the (C:) drive can be performed by accessing the Recovery Partition.
(If the Recovery Partition is not accessible by pressing the F10 Key while restarting the Computer, the only option is to purchase the Recovery Discs and perform the System Recovery.
Please follow the below steps to access the Recovery Partition and restore the Computer to the factory default.
Note: Restoring the Computer to the factory settings will erase all the Data on the Hard Drive and restore it to the factory condition.
  1. Restart the Computer, press and hold the F10 Key.
  2. If and Edit Boot Options Screen appears, press the Enter Key.
  3. This will launch the VAIO Recovery Center window.
  4. In the VAIO Recovery Center window, please select the Restore C: Drive option.
  5. Next to the "Restore C: Drive", please click the "Start" button.
  6. Under Before Restore C: Drive , ensure the Skip option is selected, and click the Next button.
  7. Under WARNING: This program deletes all files on the C: drive , click to select the I understand box.
  8. Then, click the Start button.
  9. After the bundled applications are installed, click the Finish button.
  10. The computer will restart and the operating system setup wizard will begin. Follow the on-screen instructions to complete the setup wizard.
  11. This should restore the Computer to the factory defaults.
May 14, 2010 | Sony VAIO VGN-FW370J/H Notebook
How to restore factory recovery system
If you still can boot it in windows, follow this:
Step 1: Click “Start” menu.
Step 2: Click “Programs.”
Step 3: Click “Acer Recovery Management.”
Step 4: Click the “Restore” button on the bottom of the dialog box that opens.
Step 5: Click “Restore System to Factory Default.”
Step 6: Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7: Click “Start” to restore the computer to the default factory settings.
If you can not boot to windows, follow this:
1. Restart the laptop
3. Follow the on-screen instructions to perform system recovery
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
I forgot my password for my psp now i cant use it what can i do?
Hello gracielarobl
You will need to restore the default settings. To do this, follow the following instructions:
STEP 1
From the XMB home menu, go to Settings > System Settings > Restore Default Settings
STEP 2
The message "Do you want to restore default settings?" should appear. Select "Yes", and press the "X" button.
STEP 3
You will then see a message, "All settings will be returned to default settings. Are you sure you want to continue?". Select "Yes" and press the "X" button.
STEP 4
All settings are now restored and the system password is reset to "0000".
STEP 5
Press the "X" button to re-start the system.
STEP 6
Re-enter system settings as appropriate.
N.B. The Restore Default Settings feature will erase any previously saved settings and restore all the settings to default.
Hope this helps. Please don't hesitate to contact me should you require any further assistance.
ajblaj
May 03, 2010 | Sony PSP-3000 Black Console
I want to restore my windows 98
Under normal circumstances, Windows is capable of detecting and recovering from registry errors automatically. If Windows is incapable of this, a previous copy of the registry can be restored manually. Windows makes and stores a backup of the registry when you start your computer successfully each day. By default, five previous copies or the registry are stored. To restore one of these previous copies:
  1. Start your computer, press and hold CTRL, and then choose Safe Mode Command Prompt Only from the Windows 98 Startup menu. If you are running Windows Me, start your computer with the startup disk.
  2. At the MS-DOS prompt, type cd\windows\command, and then press ENTER. Where windows is the name of the folder in which Windows is installed.
  3. At the C: prompt, type scanreg /restore, and then press ENTER.
  4. Select the previous registry you want to restore, and then press ENTER.NOTE: A properly working registry has the word "Started" next to the date.
  5. When you receive notification that you restored a properly working registry, press ENTER to restart your computer
Apr 23, 2010 | Microsoft Windows 98 for PC
Warning message at boot up,non-responsive keyborad
Try this! Open your CPU there you will find CMOS battery remove it and reinsert and there will be a BIOS pin remove it and reconnect. Now Switch On the system.
Jan 13, 2009 | Micro Direct (SYSMDBGAMBASE004) PC Desktop
ASUS P4S800D-X Motherboard Logo
128 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
