Question about Epson Stylus 680 InkJet Color Printer
Ref EPSON STYLUS 680 printer paper feed problems ,fails to feed paper but motor runs
  • 484 Answers
Have you checked to see whether the sensors are not blocked by excessive paper dust? Do you know whether the printer is set to pull in a specific type or weight of paper?
Oftentimes, if you have printed on a heavy weight type of paper, or on a glossy type of paper for printing photos, when you next try to print,you forgot that the printer had been set for a different kind of paper ... one which requires the printers transport rollers to grab a heavier, or shinier type of paper, and now, when you try to print on regular paper, the printer;s rollers are simply not able to grab that kind of paper. so no matter of any types of paper or times they try to fix it, if they do not set it using the printer's 'properties' software button, they will not get it done right, and the printer will simply slip or slide but not grab the paper correctly.
Do it from within the printer's control panel and you will have a much better chance of having it work right.
Try that and see if it doesn't solve your problem.
-a.
Posted on Nov 06, 2009
    Sniper:
  • 70 Answers
Try to look on the input tray maybe there are some foreign object that might block the paper,because this kind of printer has a durable pick up roller.
Posted on Sep 09, 2009
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Epson Stylus C62, Yanked overfed amount of paper from printer. Printer was jammed. Paper would not feed. After yanking out paper the carridge will not return, paper wont feed, printer shuts doown after a...
Probably not - a belt was either yanked out of its cog or a roller was popped out of its bearings. Since you have nothing left to lose just dismantle the printer (only a screwdriver is needed) and try to put the parts back together. If you fail, just get a new one.
Aug 27, 2010 | Epson Stylus C62 InkJet Printer
My Epson Stylus SX515W won't feed 250gsm greetings cards, even if I help them a bit! My old Colour 680 worked fine.
Epson recommends you use Epson media if a third-party heavy (card stock) media has feed problems.
The printer (depending on the model) should be able to take 255 g/m2 or 300 g/m2 genuine Epson media.
I wish that I could be of more helps.
May 14, 2010 | Epson Office Equipment & Supplies
Red light keeps flashing on EPSON 680
no, he can print only if he download a driver for his printer
Mar 08, 2009 | Epson Stylus 680 InkJet Color Printer
Epson 680 Stylus - Paper Jam button
Have you run the Epson printer utility? This should answer your problem if you run it. I had a similar problem and the utility reccomended to get the printer serviced as a component had become faulty. If you dont have the utility you can download it from the epson site for free.
Jul 06, 2008 | Epson Stylus 680 InkJet Color Printer
Printer driver lost and need to install
Give us a clue! What OS are you using and what language do you need. If you want an XP driver in Dutch, English, french, German, Italian, Portugese or Spanish or Mac OSX Driver in English I can help.
Apr 02, 2008 | Epson Stylus 680 InkJet Color Printer
Epson Stylus 680 InkJet Color Printer Logo
261 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
