Question about Motorola Mobility SLVR L7 Cellular Phone
How can i delete the names from the web session of my MOTOROLA L9
The list of web session list is full ,,so i cant access aircell pocket internet.plzzz help.
Web sessions Deleting
you may select master clear or manually change the web session name and setting with all the data from respective networks
May 01, 2013 | Motorola Mobility MOTORAZR maxx V6...
In the web sessions the wap is locked and i can't access internet.how to unlock..
Using P2Kman, download the file /a/WebSession
Open this file in your XVI32.
You'll see the information from each profile under Web Access > Web Sessions
To unlock a web session, find the name of the web session in the file on the text side.
Look at the three offsets prior to the first letter on the hex side.
You should see 03 05 00. (You may see 01 05 00.)
Change the middle number to "04". (You should have 03 04 00 or 01 04 00.)
Reupload the WebSession file to the /a/ directory.
Make sure you change the attribute on the file to "4"
Restart your phone and you can now edit or delete that web session!
Jan 17, 2011 | Motorola Mobility RAZR V3i Cellular Phone
I want the manual gprs settings for motorola L6 bcoz aircel is now showing the service is not available.
Go to
Menu - Web access - web sessions - Create New sessions - Enter the data
For Aircel
Name - Aircel (Any name will work)
APN - aircelgprs
Rest everything blank
Dec 31, 2010 | Computers & Internet
Sir I am unable to set my vodafonelive on my motorola l9 slvr set please give me mannual setting in paticularly thanks kamal
Manual Vodafone Live GPRS Settings
Settings Name: any
Home Page: http://www.hutchworld.co.in
Session Mode: Permanent
Connection Security: off
Data Bearer: GPRS
GPRS Access Point: portalnmms
IP Address: 10.10.1.100 Use proxy? yes
Authentication Type: Normal
Login type: Automatic
User Name: <blank>
Password: <blank>
Activate Vodafone GPRS through SMS If the above settings does not work for you, you can sms to vodafone server to activate vodafone live or vodafone mobile connect.
  1. send ACT VL to 52586 to activate Vodafone live! (MMS & Wap Access),
  2. send CAN VL to 52586 to deactivate Vodafone live!, send ACT VMC199 or ACT VMC499
  3. ACT VMC699 to 56789 to activate Vodafone Mobile Connect (Web Access on phone or Laptop/PC)
Dec 27, 2010 | Motorola Mobility L9 Unlocked GSM Cell...
only web sessions which doesnt have lock on the right side will get deleted for others u need to format the mobile
Jan 31, 2010 | Motorola Mobility SLVR L7 Cellular Phone
How to access aircel pocket internet in laptop through motorol l9
First of all ask for pocket internet setting or AircelGPRS setting from your service provider by calling on its customer care no. then after getting it save in your mobile then select it as default then restart your mobile then connect it to PC through cable then set a new connection give APN-aircelgprs in small letters.then connect it u will be able to access net.
Jul 17, 2009 | Motorola Mobility L9 Unlocked GSM Cell...
I AM NOT ABLE TO RECIVE THE SETTINGS FOR THE MOBILE ,ITS MOTOROLA V3 SO COULD U SUGGEST THE MANNUAL SETTINGS I CAN DO FOR AIRCEL POCKET INTERNET
I have a V3, but I don't use the same service provider as you.
Go to WebAccess > WebSessions and delete some sessions incase the list is full (Yes it has a maximum limit).
Now send the sms to download settings, which you can obtain from customer care
Now go back to sessions and choose Aircel and set Aircel as your default connection.
Hope it works,
Cheers
Jun 19, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Aircel gprs not connected
Call you Aircel customer care and ask them to send the GPRS settings.
Once you receive the GPRS settings store it.
Now go to Menu->Browser->Web Session->Aircel or Aircel Live.
Now switch off and switch on your mobile.
Now you can browse from your device W230
Cheers...!!!
Mar 31, 2009 | Motorola Mobility W230 Phone US with...
How to delete web session from motorola l6 phone
I would like to delete some of the web sessions from the existing list. Please help me.
Mar 03, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Problem..
reset your phone on factory setting
Oct 07, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
381 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
