Question about Refrigerators
I unplugged my kenmore icemaker and the ref stopped working.Plugged it back in and it still doesn't work
  • SELambirth May 11, 2010
    What exactly did you unplug, and what model do you have?
  • 93 Answers
You may have shorted something. Try unplugging the refrig and plugging it back in. Some refrigerators have to have the control board programmed when it is turned back on.....you have to hit the door switch x amount of times and put a code in the display.
Posted on Sep 13, 2009
The Ice Maker stopped workingon my Kenmore Trio
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 20, 2011 | Kenmore Refrigerators
My HSE02WNAPG Haier was working just fine...until it froze everything inside (I found out when I returned to work to find 2 exploded sodas...whoops). I unplugged it to make sure everything was thawed and...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Leo Ponder
imufo2
Sep 19, 2011 | Haier HSE02WNAPG 1.8 Cu. Ft. Compact...
Hi, We have a Kenmore fridge Model 596.61852101. It seems to have stopped working. Everything in the freezer is melting and it doesn't feel very cool. It's plugged in and was working earlier today....
NOTE: This
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
But is probably a common defrost problem The ice build up
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 09, 2011 | Kenmore Refrigerators
Side by Side Kenmore fridge, model# 1069545751, s/n sd3114601, ice maker stop working
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
I'm
Leo Ponder
imufo2
Sep 04, 2011 | Kenmore Refrigerators
I have a Kenmore side by side 596.57582790. Ice machine dispenser stopped working then a week later the water dispenser stopped. Pulled out the fridge to check to if there was a problem with the...
NOTE: This
I'm
Leo Ponder
imufo2
Aug 22, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our freezer is working, but the fridge portion is at 15'C with max cool on freezer and fridge. I have unplugged it and am defrosting it. What could I look at while it's unplugged?
NOTE: This
I'm
Leo Ponder
imufo2
Aug 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I HAVE KENMORE ELITE FRIDGE MODEL 106.56692501 AND THE ICE MAKER STOPPED WORKING. THE RED LIGHT FOR THE ICE MAKER IS RED AND BLINKING
NOTE: This
I'm
Leo Ponder
imufo2
Aug 14, 2011 | Kenmore Refrigerators
Ice-maker stopped working
Pour Water manually in Ice maker and wait for ejection. If it ejects then the water mixer valve
underneath the rear of the Ref is defective. If it doesn't eject then the icemaker itself is the fault.
Leo Ponder
imufo2
Jul 16, 2011 | KitchenAid Refrigerators
Ice maker not working on kenmore top moun t freezer
Suddenly my icemaker stopped making ice. I have a Kenmore ref. with a top freezer.
May 09, 2009 | Kenmore 64802 Top Freezer Refrigerator
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
