Question about Panasonic Lumix DMC-LZ5 Digital Camera
NO POWER My Lumix DMC-LZ5 has no power. Replaced batteries with new ones still no power, is there a reset button .........
  • erdeigergo Oct 03, 2008
    Hello
    I like my dmc lz5 very much, durable, trustable...
    First time same problem here,
    New batteries, they work fine in flashlight,even for longer time, but dmc-lz5 displays replace batteries.
    After dismounting back panel, I have found inside a button-battery 1 mm thick 6mm diameter,
    it turned out it is a special, rechargeable one, it gives 3 v, but it can use a charging voltage as low as 2.8 v.Earlyer I tought this was the problem- because I have used the camera with rechargeable batteries, (those give 2x1.2=2.4 v , less than 2.8 ).I bought alkalines, giving 2x 1.5 = 3 v , but after about 50 pics taken the problem is here again.Now i try to replace the button battery (type panasonic ml-614), hoping this is a problem.
    Anyone having some solution or similar case?
    Thank You
  • 3 Answers
Http://www.fixya.com/support/t1100571-lumix_dmc_lz5_replace_battery
Posted on Oct 07, 2008
Make sure u arent using any uber cheap batteries, cuze i used a pair of panasonic heavy duty and they died after 4 shots D=
Posted on Dec 21, 2007
Lz5 card does not work
Make sure you're using an SD card, 2GB and smaller. The DMC-LZ5 will not work with higher-capacity SDHC cards.
Dec 01, 2012 | Panasonic Lumix DMC-LZ5 Digital Camera
What is max size memory card for lumix dmc lz5
Although it's not the newest device out there, an SD card of 4gb would be more then suitable for it, check the manual for more info about the limitations which your device has:
Panasonic DMC LZ5 Manual
Dec 28, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
HOW TO TRANSFER PICS FROM LUMIX DMC-LZ5
I take it you mean to a computer - Buy a card reader with a USB connection or use the cord that came with the camera. You should have software that came with the camera that you first place on the computer. If not try the free program Irfanview.
Dec 28, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Where can I get a operators manual for my dmc-lz5
Click Panasonic Support to download instruction manual copy of DMC-LZ5 camera.
Thanks.
Dec 15, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
I have a lumix panasonic model DMC-LZ5 when it turns on the battary indicator indicats that the battry is empty although it is fully charged
This is a battery contact problem, the DMC's are horrible for it. Firstly as the previous answer said, take the battery out and clean the 3 copper tops (scrape them with a knife tip to remove ****) and secondly, make sure it is seating well into the battery cavity, you may want to pop a bit of tape on the back end of the battery so it is pushed in a little deeper by the door when it closes.
Apr 04, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
Lumix dmc-lz5 replace battery
Try replacing the button battery first and see if that helps...Some batteries simply just do not last as long as other brands. Try switching brands (for the regular AA batteries) and see if this also helps..
Oct 03, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
Lumix dmc-lz5
Cleaned is not the problem. Most of the time it is poor battery. Just becuase the battery says it is charged means nothing. These cameras take a great deal of power compared to other AA devices.
Sep 29, 2007 | Panasonic Lumix DMC-LZ5 Digital Camera
Panasonic Lumix DMC-LZ5 Digital Camera Logo
416 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
