Question about Compaq Presario 5000 PC Desktop
My compaq v6000 does not come on. Shuts itself down when power power is pushed.
  • morningstar2 Sep 10, 2009
    Dear savageinjun,
    I did shut the computer down for the night. I went to start and shut windows down. At that time all was running fine. My children were playing games the next evening and the screen went black, it would not respond to any of my attempts to restart so I unplugged it and took the battery out in hopes that it would reset. Now it comes on and then shuts itself down. Windows does not attempt to boot. I'm using Vista if that may help.
    thank you, morningstar
  • savageinjun May 11, 2010
    this could be due to a number of reasons..bad ram..corrupt bios..dead hard drive..in need of new psu(power supply unit)..old age..hahahaha..kidding on last one...only trying to make light of your situation..:)..ok..first off..was it running normally before you shut it down for the night( or whatever reason) did you mess with the registry?? virus infection?? hardware change (new graphics card/new ram/etc) ?? what were you doing before you shut it off..or did it just shut down on its own(again,,what were you doing) and no longer powers back up?? there is always a reason and an answer to your question..i just need more information..i can't just tell you to open it up and take a screwdriver and tap on something inside your comp in hope that it will magically boot up. please..details thanks and then i'm sure i'll be able to help you fix it over the net. never ever let anyone "repair" your computer thru "remote/secondary logon" as you might as well open your door, put on a blindfold and tell everyone to come in and do what they want all the while you are blindfolded. waiting for your reply. :)...savageinjun?®
    Master:
    Sergeant:
  • 460 Answers
It is a hardware problem. SMPS or CPU fan has been faulty of your system. so pls ckecked it from computer vendor
Posted on Sep 09, 2009
How do i get my headphone working on my compaq v6000
Double-click the "sound" icon at bottom-right of the computer screen.
Check that the speakers are not "muted".
If the speakers require power, make sure that they are powered-on.
Turn up the volume on the speake itself.
Using the "sound control", increase the sound-level going to the headphones.
Sep 28, 2014 | Compaq Laptop / Notebook Video-336970-001...
4 beeps in compaq v6000 lp
ok try this shut down laptop hold down function key microsoft button the B button and power all at the same time will put you in bios look forset to default settings and save and exit let me know what happens
Mar 03, 2013 | HP Compaq Presario V6000T Notebook PC
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
Compaq Presario V6000 not turning/powering on
This can be a tricky problem indeed. As a matter of fact, I'm experiencing a similar problem myself. I don't know if you have done this or not so I'm going to throw it out there:
Have you tried plugging it into a charger and starting it? If so, how about without the battery?
Also, if the laptop isn't charging, check to see if the charger is faulty. The end could be bent, or something inside could simply not be working.
The most likely problem if none of these help is that the port itself is shot. In that case, you'll have to take it to a computer shop and have them diagnose it for you just to be sure.
Hope I was of assistance.
Nov 28, 2009 | Computers & Internet
I need for my compaq presario v6000.
You can get the wireless drivers in the laptop itself. U need to type in the start search as recovery manager and when the window is opened, click on the advanced options and select the option hardware driver installation. Search for the sound driver and select it and it get re-installed. If this doesnt work try to go to hp.com and select support and drivers and enter the product number of the laptop and follow the onscreen instructions.
Thanks and Regards
Honey
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Compaq v6000
i want ALL drivers for my compaq presario v3500 model no is V3611AU FOR WINDOW XP PROFs.
Sep 11, 2008 | HP Compaq Presario V6000T Notebook
Compaq presario v6000 laptop powering down with no warning
If not, then the keyboard cable has probably come loose.
Look for some way to remove the keyboard. Sometimes a screw from underneath, sometimes two or three small catches at front of keyboard (small gaps in metal plate in front of space bar). Sometimes top plastic bar above keyboard slides sideways.
Keyboard cable uses goes into a header socket - to refit:
Switch off and remove battery and power first!
1. Prise up each end of the socket with a blunt knife - the outer part of the socket should move up a few mm
2. Push keyboard cable down fully
3. Push down each end of the header socket so it is flush with the lower part of the socket.
4. Test keyboard
Aug 20, 2008 | Compaq Presario Notebook
Need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
Jul 31, 2008 | HP Compaq Presario V6000T Notebook
Presario V6000 laptop
sounds like a motherboard issue ,
can you take the drive to another computer and check the contents are still accessible.
If contents are accesible then the motherboard is poked.
replace device and start again.
There is no cheap fix for this one unfortunately.
Keep me posted with your outcome thanks
Jul 20, 2008 | HP Compaq Presario V6000T Notebook
User manual for compaq presario v6000
Is the microphone available on compaq presario V6000 model for using skype
Feb 19, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
211 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
