Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
I want graphics - Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
  • 674 Answers
Download from the ineternet.. you should knnow the exact model of your system then type in google search bar.. it will givve you the links to select it then download (ex. support ..model) enter
Posted on Sep 09, 2009
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | Computers & Internet
What is visual graphic acdactor ,and the freze
A video card (also called a video adapter, display card, graphics card, graphics board, display adapter or graphics adapter) is an expansion card which generates a feed of output images to a display. Most video cards offer various functions such as accelerated rendering of 3D scenes and 2D graphics, MPEG-2/MPEG-4 decoding, TV output, or the ability to connect multiple monitors (multi-monitor).
Video hardware can be integrated into the motherboard or (as with more recent designs) the CPU, but all modern motherboards (and some from the 1990s) provide expansion ports to which a video card can be attached. In this configuration it is sometimes referred to as a video controller or graphics controller. Modern low-end to mid-range motherboards often include a graphics chipset manufactured by the developer of the northbridge (e.g. an AMD chipset with Radeon graphics or an Intel chipset with Intel graphics) on the motherboard. This graphics chip usually has a small quantity of embedded memory and takes some of the system's main RAM, reducing the total RAM available. This is usually called integrated graphics or on-board graphics, and is usually low in performance and undesirable for those wishing to run 3D applications. A dedicated graphics card on the other hand has its own Random Access Memory or RAM and Processor specifically for processing video images, and thus offloads this work from the CPU and system RAM. Almost all of these motherboards allow the disabling of the integrated graphics chip in BIOS, and have an AGP, PCI, or PCI Express slot for adding a higher-performance graphics card in place of the integrated graphics.
Aug 31, 2012 | Computers & Internet
Upgrading graphics quality on my pc.
There is a large range of graphics card on the market in both performance and prices to match.
The graphic card that suits your requirements depands upon what you want in terms of performance and the application that requires a particular level of graphic capability.
Check the software documentation or games program for the graphic card that is required to run with their program. Generally games programs that require photo realistic rendering require high end graphics cards.
You may select a graphic card that is a bit above your current requirements to cover for future requirements.
I suggest you Google search the Internet or go to your computer shop to see what is available that meets your requirements. You can spend a lot of money on a very high end graphics card when a lessor graphics card would still suit your requirements and not burn a hole in your pocket.
Jun 15, 2012 | Gigabyte Computers & Internet
Where is my graphics card
Laptops usually don't have a separate graphics card (unless they are very new or very high end). They have a graphics chip that is part of the motherboard.
..In other words: you can't replace them or fix them if something is broken.
Apr 06, 2012 | Acer Computers & Internet
Computer dell latitude D610 built in 2006 replacing the viedo card how too's and also what can I do to mabe upgrade this veido card? and dose anything else need to be updated at the same time as the...
Sorry Jimmy, the Dell Latitude D610 Notebook PC uses Integrated Graphics.
There is no graphics card to upgrade.
Your Dell either came with a form of the Intel GMA graphics chipset , or the ATI Radeon Mobility X300 graphics chipset.
http://support.dell.com/support/edocs/systems/latd610/en/ug_en/specs.htm
Either/Or
The way Dell states it, (And also this is for a LOT of laptop manufacturers), is that you have either the option when purchasing, of having an Intel GMA chipset for graphics, or discrete graphics of the ATI Radeon Mobility X300, for graphics.
Discrete being the word that fools people. Makes them think it has a dedicated, removable graphics card, when in reality it is a graphics chipset soldered directly to the motherboard, and is not upgradeable.
Primer:
GPU
Essentially the 'graphics engine'.
A GPU can be installed directly on the motherboard, (Integrated Graphics), OR installed on a removable graphics adapter card. (Graphics Card is shortened for graphics adapter card)
Integrated Graphics borrows from the system resources. The Processor and Ram Memory.
This is why programs, for example games, that use a lot of graphics 'power', do not perform well on a computer with Integrated Graphics.
{Read - programs that use a lot of graphics power. Such as some of the newer games. Integrated graphics, depending on what graphics chipset it is, CAN run some games. Ones that are not very graphics intensive}
A dedicated graphics card has it's own processor, and graphics ram memory. Does not need to borrow from the system resources.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The graphics chipset in your Dell Latitude, is mounted to the motherboard with a BGA surface mount.
Ball Grid Array
http://en.wikipedia.org/wiki/Ball_grid_array
To explain the BGA surface mount;
Let's use the older Intel Pentium 4 processor that uses a Socket 478 processor socket.
The bottom of the processor has contact pins. (478 of 'em)
The processor socket has matching socket holes for the contact pins. (478 of 'em)
With the BGA surface mount there are no contact pins. In place of them are Solder Balls.
There is no socket, or socket holes on the motherboard.
There are Copper Pads.
The graphics chipset is set into place with the Solder Balls lining up on the motherboard's Copper Pads.
Then heat is applied at a specified temperature, and length of time.
The solder balls melt which solders the graphics chipset to the motherboard. (To the Copper Pads)
Removal and replacement is properly performed with a BGA Rework Machine.
Costly, and not something you'll find a local shop performing.
{The machine is costly, and the operator needs to be S-K-I-L-L-E-D. Cost of having a chipset replaced is Ouch!}
There are two ways you can upgrade your graphics.
1) If you have the motherboard model with a form of Intel GMA chipset attached, you can purchase the motherboard that has the ATI Radeon Mobility X300, and install it.
2) Purchase a laptop with better graphics.
{Not trying to be snide}
Regards,
joecoolvette
Oct 25, 2011 | Dell Latitude D610 Notebook
Hello sir I've intel desktop computer. when I play high graphic video, the screen goes blank & dark
HI, Regarding this issue please do update the graphics card driver for your computer.
Nov 19, 2010 | Computers & Internet
Was wondering if it can be replaced with a better graphics card
This depends, mspolar1.
Depends on;
1) If it's a Desktop computer, or a Laptop computer.
Desktop computers may, or may not, come with Integrated Graphics.
For those desktop computers that do Not, a graphics adapter card is used.
(Graphics adapter card is also referred to as a Graphics Card, or Video Card)
Desktop computers that Do come with Integrated Graphics, will also have a graphics expansion slot to install a graphics card in.
2) Laptops generally just have Integrated Graphics, BUT there are some models that Do have a Graphics Card, and there is the possibility of upgrading to a better one.
The above relates directly to Toshiba desktop computers, and laptops, as well as a reference to all desktop, and laptop computers.
To explain Integrated Graphics:
Another name for Integrated Graphics is OnBoard Graphics.
ON the motherBOARD.
The graphics chip is soldered directly to the motherboard.
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
A graphics chip has a GPU on it,
http://en.wikipedia.org/wiki/GPU ]
Integrated Graphics borrows some of the system's resources.
The Processor and Ram Memory are trying to take care of the Operating System, and the program that is being ran.
Two Operating System examples are Windows XP, and Windows 7. An example of a program that may be borrowing system resources heavily, is a game.
If an intense game is being played, the system resources cannot keep up with the demand for graphics, when Integrated Graphics is installed.
(Slow frame rates, or freezing. Poor graphics. Even with low settings)
A dedicated graphics card borrows very little of the system resources, or none at all.
A graphics card has it's own Processor, and Ram Memory.
(GPU and graphics ram memory)
In direct reference to Toshiba laptop's, post the laptop Model Number to see if the graphics can be upgraded.
There are some Toshiba laptops where this is possible, and some that are not.
(Post in a Comment)
The one's that use Integrated Graphics, and no dedicated graphics card, are the ones that cannot be upgraded.
Oct 29, 2010 | Toshiba Computers & Internet
Video card....
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Feb 07, 2010 | Toshiba Satellite Laptop
My e machine dekstop m w3503 is using only 368MB of ram out 512MB why Jose
Approximately 144MB is being used by the Integrated Graphics, and other resources.
(Computers use a GPU. Graphics Processing Unit. This is a chip that is soldered to the motherboard, {Integrated Graphics}, or is soldered to a graphics card.
[Integrated is also referred to as Onboard. On the Motherboard]
Chip is a shortened, or slang term for IC. Integrated Circuit,
(A Processor is one example of an IC)
Integrated Graphics shares some of the system's Ram Memory. The GPU installed needs to borrow from the computer system.
This is perfectly normal.
This is also why a graphics card, speeds up graphics processes. A graphics card has it's own graphics processor, (GPU), and graphics ram memory.
Nov 30, 2009 | E-Machines eMachines Desktop PC
I have installed a game that needs graphic card software
NEW TO GOTO PROPERTIES OR CHANGE RESILLUTION OR GRAPHIC CARD SETTING
MY GRAPHICS CARD HAS SETINGS FOR CERTAIN GAME TO MAKE THE SYSTEM GRAPHIC BETTER AND LOADS SPECAIL DRIVES FOR THAT GAME ONLY ORDERED BY THE GAME MANUFACTURE SETTING TO GIVE YOU THE BEST PERFORMANCE FOR THAT VEDIO CARD IF NOT
GO OT WEB SITE LISTED BELOW
TYPE MANUFACTURE NAME IN ADDRESS BAR AND ENTERKEY
DRIVERS
Jan 28, 2009 | 3dfx Voodoo4 4500 (32 MB) Graphic Card
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
32 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
