Question about Bush Televison & Video
I have a bush vcr/dvd combi F09a02595 /I set it up/ put a cassette tape in/ the word lock came on/ and what ever I do I cannot get by it. I am aged and cannot solve it. Thank you cliff
I had not read instructions correctly/ by pressing the standby button for 8 seconds it solved the problem
thank you
cliff_chappe
Posted on Sep 10, 2009
I start to play a VCR tape and it just stops playing and the machine turns off. This doesn't happen with a DVD, however.
The VCR tape will turn off when spools are Jammed to prevent breakage of the tape. Take out the VCR cassette and put a thick pencil in the each sprocket hole and try winding in the right direction (which means when you manually wind the tape the other spool should unwind without resistance). If you feel resistance the sprockets are jamming. Knock the cassette on a hard surface without breaking it and usually it will free the jam. If does not help then carefully open the the cassette screw and re-position the sprockets.
Mar 29, 2015 | Televison & Video
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Why do my vcr eat taps
Every VCR has a transport mechanism that moves the tape-when eject is hit it reverses and winds the tape back into the cassette and closes the door on the tape BEFORE the tape exits the unit.
It is not doing that so the tape gets mangled--bad belts, bad rubber drive wheel etc---all happen with age even if unit is not used much.
Parts for these are getting hard to find--if any questions post a comment here.
SD TECH
Apr 26, 2012 | Philips Magnavox DVD/VCR Dual Player
I HAVE A BUSH VCR/DVD COMBI WHEN I RECORD ON LP IT PLAYSBACK ON SP AND LP ALTERNATIVELY
This sounds like dirt on the heads. Try cleaning the Main Video head the audio/tracking head and anything else that where the tape touches, with Servisol Video 40, from Maplin or Radio Shack etc.
Sep 14, 2009 | Televison & Video
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
VCR Problem
your cassette may be too stuck & strong for the vcr to load. or check if the vcr set of driving & loading belts are not slack
Oct 12, 2008 | Samsung DVD-V1000 DVD Player/VCR
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Televison & Video Logo
186 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
