I just bought 2 1g ddr2 ram seperate, did not buy them in the same package but same time and place. when i got home i realized one stick looked completely different from the other. the packaging and labeling on the packaging suggests that they're both exectlly the same. one has 8 solid black chips on each side and isn't the same thickness or exactlly the same height, and they have different part numbers,the other has only 8 chiips on 1 side what do i have here exactlly? pny ddr2 pc2-5300 optima memory 1g per. and on the package all 3 of the mhz are checked not sure what that means either 667 mhz 533 and 400... so which one is it? and is this the right memory for my upgrade on my gateway gt5453e pc, motherb ht2000 64bit dual amd motherboard limit of 4 gigs i think or maybe it was 8 not sure. and 1 more question will this memory work smothly with unbuntu?
  • 2 more comments
  • ariesrose13 Sep 09, 2009
    ok thanks but you didn't answer some of my question... so what do i have here? did you read the whole query? (i just bought 2 1g ddr2 ram seperate, did not buy them in the same
    ddr2 pc2-5300 optima memory 1g per.) they both will fit but obviously there is a difference in.
    so no matter what mhz the ram is that i buy my system will only run it at 533 mhz? is that true? and what does that mean for the capabilities of my system? should i get more ram to comensate?
    did you get that last message rom me? i'm falling asleep please hurry. so i should but that mhz and not try to step it up to a faster memory? so this will never be a gaming computer or a god server?
    i just bought 2 1g ddr2 ram seperate, did not buy them in the same package but same time and place. when i got home i realized one stick looked completely different from the other. the packaging and labeling on the packaging suggests that they're both exectlly the same. one has 8 solid black chips on each side and isn't the same thickness or exactlly the same height, and they have different part numbers,the other has only 8 chiips on 1 side what do i have here exactlly? pny ddr2 pc2-5300 optima memory 1g per. and on the package all 3 of the mhz are checked not sure what that means either 667 mhz 533 and 400... so which one is it? and is this the right memory for my upgrade on my gateway gt5453e pc, motherb ht2000 64bit dual amd motherboard limit of 4 gigs i think or maybe it was 8 not sure. and 1 more question will this memory work smothly with unbuntu?
    Comments:
    redhaze89
    redhaze89
    Rank: Guru
    Rating: 85.20% , 125 votes
    Your pc supports 533 megahertz.
    Yes, If you plugged in you new RAM. And it booted. ...Any Operating system will support this.
    If the memory module didn't fit in the slot...you need to send it back for replacement. I would also suggest to send along your CPU set to the store where you bought so that they will have excuse to give you the right memory module. You need to let them install in you pc motherboard. Let them show you that you have 2 gig reading on the motherboard. Most of the pc store has its technician and they should help you determine this..
    hope this helps
    Sep 09, 2009
    - ok thanks but you didn't answer some of my question... so what do i have here? did you read the whole query? (i just bought 2 1g ddr2 ram seperate, did not buy them in the same package but same time and place. when i got home i realized one stick looked completely different from the other. the packaging and labeling on the packaging suggests that they're both exectlly the same. one has 8 solid black chips on each side and isn't the same thickness or exactlly the same height, and they have different part numbers,the other has only 8 chiips on 1 side what do i have here exactlly? pny ddr2 pc2-5300 optima memory 1g per.) they both will fit but obviously there is a difference in. so no matter what mhz the ram is that i buy my system will only run it at 533 mhz? is that true? andwhat does that mean for the capabilities of my system? should i get more ram to comensate?
    pretty much but i wanted a little more explaination on the difference between the 2 more technical of an answer. but yeah now i can go ahead and install the memory
    Brigadier General:
  • 5,158 Answers
The memory in your computer is
  • Installed: 1024 MB DDR2, 533 MHz, (PC4200) dual channel memory (two 512 MB DIMMs)
  • Expandable to: 4 GB total memory (4 DIMM DDR2 slots)
  • from this description you have four slots in your computer. so add those two and you should have 3 gig of memory if it was in the original configuration.
    the amount of chips isn't as important as what the lable says they are. basically if it has all three speeds (mhz) marked it will run up to the maximum speed shown.
    robert
    Posted on Sep 09, 2009
    • 854 Answers
    hope this helps
    I am trying to upgrade my RAM to 2gig. The manual says that this is the max I can put in. I have installed 2 seperate sticks of 1g of ram yet my system is only showing 1gig. Do I need to update my...
    It sould work.
    Remove both chips and reinsert. make sure you insert the chip fully and keep pressure on it untill it clicks in to place. do that for both chips.
    If you still have only 1gb try the chips one at a time and in different slots to see if oyu have a bad chip.
    Good luck.
    Note the type*
    DDR2 PC2-5300 • CL=5 • Unbuffered • NON-ECC • DDR2-667 • 1.8V • 128Meg x 64 •
    Sep 07, 2011 | Computers & Internet
    Computer freezes during booting
    Quite possibly a bad stick of RAM. Is it an older computer? If it's new, and covered under warranty, pursue that with the place of purchase. It's a LOT cheaper to buy a stick of RAM yourself than to get someone to do it for you, so check the bottom of the laptop. There should be a couple of panels that can be unscrewed. The one you're looking for should be roughly 4" by 4 or 5". Open it up, and check the sticks of RAM. Is there one or two? They look like this: http://ddr2laptopmemory.net/wp-content/uploads/2010/07/ddr2-laptop-memory.jpg Make sure your computer is off when you check/remove/replace RAM sticks.
    If there are two RAM sticks, remove one, and then start it. Still freezes? Carefully replace the stick you removed MAKE SURE it is firmly reseated, and remove the other stick and reboot. This should do it. If it is starting normally, take the faulty stick of RAM into a computer repair or product shop, and ask for a stick of DDR2 laptop memory. Make sure it is the same size 1G, 512MB etc as the stick you removed, as RAM usually likes to be the matching amount with its friend. If it has one RAM stick, remove it, take it to a computer shop, and buy the same size stick. It's easy to install yourself. Hope this helped, any further problems, please let me know and I will be happy to help.
    Jul 19, 2011 | Dell Inspiron 1525 Notebook
    How to replace memory on hp s7320n
    Go to www.support.hp.com.
    Enter s7320n on the "Enter your product number space" and click next.
    Click on "How to"
    Click on "Adding/Replacing hardware"
    Click on "Upgrading Memory (RAM)"
    Follow the instructions on this page and have fun!
    Oct 31, 2010 | Computers & Internet
    I currently have 2 x 1GB 667mhz ram in the yellow slot and I am thinking of buying 2 x 2GB ram but do I have to get the same Mhz or am I able to get a higher speed.
    You have to buy the right "family" of ram. Your system needs DDR2.
    You can buy any DDR2 and it will fit into your motherboard but your system specs are for DDR2 800 (also called PC2 6400)
    You could buy 1066 (PC2 8500), which is faster, but it will run @ 800 instead of 1066 because your system is rated at 800.
    So buy whichever is cheaper. Try to buy them in sets (matched pairs - 2 sticks of ram in same package).
    Buy memory with good reviews (and prices) check newegg.com
    Feb 16, 2010 | ASUS M2V Motherboard
    Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
    with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
    thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
    post a coment if this does not work.
    thanks,
    wonder
    Sep 18, 2009 | ASUS P5VDC-MX Motherboard
    I went to Newegg to view the ram for my Acer Aspire One 10.1''. Which brand of module would be best for this model netbook? Thanks. fldtpww@netscape.net
    There are three versions of the Acer Aspire One.
    Look on the bottom of your Acer, and see which model number it is.
    ALL of the Acer Aspire One netbooks, have One ram slot.
    For the Maximum TOTAL Amount of ram that each model number will use,
    The A110 model number uses a 1GB stick, of PC2-5300 SO-DIMM ram module.
    The D150 model number uses a 2GB stick of PC2-5300 SO-DIMM ram module.
    The D250 model number uses a 2GB stick of PC2-5300 SO-DIMM ram module.
    Not to offend, to help.
    If you are not familiar, with what a SO-DIMM style of ram module is, and/or you are not familiar with what PC2-5300 is, I suggest you buy your ram from Crucial.com
    Apr 23, 2009 | Acer Aspire One PC Notebook
    My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
    what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
    Mar 17, 2009 | Acer Computers & Internet
    What kind of ram?
    just look for notebook memory type ddr2, ddr2 all have the same amout of pins, you will have to remove one of the sticks of ram and replace with a 1GB or remove both and fit 2 x 1GB sticks.
    seee below
    http://www.ebuyer.com/store/Components/cat/Memory---Laptop
    Nov 23, 2007 | Acer Aspire 5100 Notebook
    Unaible to upgrade RAM
    It will only support up to 2GB Ram and the same memory specification
    Nov 23, 2007 | ASUS M2N-MX Motherboard
    Can 1 stick of DDR and 1 stick of DDR2 be used together
    This mother board will take either DDR or DDR2 but not both at the same time. It is stated clearly in the user manual. So if you already have 1 stick of DDR just get another stick DDR also and not DDR2.
    Oct 13, 2007 | EliteGroup P4M800PRO-M Motherboard
    14 people viewed this question
    jasbo
    jasbo
