Question about Skagen Slimline Mesh 358SGS Wrist Watch
My new Skagen clasp keeps flopping open. Anyone have any advise?
I adjusted the band and that piece holds. However, the fold over clasp flips open pretty much anytime something brushes agaiinst it. At which point the watch comes off my wrist. How do you get the folder over clasp to stay fastened?
gemineye61
  • 831 Answers
SOURCE: Where can I buy replacement
Try this link:
http://www.skagen.com/service/orderWatchBandParts.fx
Posted on Aug 09, 2010
SOURCE: how to open a ladies rolex watch band
Push the crown and lift up the crown part, it will open easily.
Posted on Apr 09, 2008
SOURCE: Shortening the Length of a Metal Wrist Band
Take your watch to a jeweler and they should do it for you free of charge.
Posted on Aug 03, 2008
SOURCE: skagen mesh band shorten
just solved the mystery...U probably have too ..by now....but just in case..
here is a fun link to the solution by an actual user....was actually inspired by him...coz like I said I had mispaced the manual...
http://www.amazon.com/review/product/B0000C9ZBX/ref=dp_top_cm_cr_acr_txt?_encoding=UTF8&showViewpoints=1
I just used my nail file and lifted the locking mechanism and moved it forward...Now I can sleep better tonite....!
Mrs Martin
Posted on Dec 27, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
How do i adjust the band on the slimline mesh skagen watch
Step 1. On the reverse of the strap you should see a succession of ridges. You will also notice a corresponding ridge on the clasp. Sounds obvious, but once you have decided where the clasp should reside on the strap, you need to align these two ridges.
The reverse of the strap
Step 2. Get a piece of string or ribbon and wrap it around your wrist. Snip the string so that one end meets the other and measure this diameter.
Step 3. On the other end of the strap you will see the hook which goes over the clasp - you will see the next picture. From this hook the measured distance will be where the end of the string lies.
The clasp mechanism - the watch is to the right of the picture
Step 4. This is the tricky bit! Insert a small screwdriver into the hole on the main clasp part, from the right hand side and bend it down towards the strap thus opening the clasp. Do not insert a tool from the left side, under the clasp and use the bar as a fulcrum; you will bend this rod and the watch strap will not hook over it. Move the clasp to the desired position and gently locate the ridge nearest the position. Once located, press down on the open clasp until it clicks into place - voila!
Related posts:
Dec 26, 2012 | Skagen Slimline Mesh 358SGS Wrist Watch
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Received Skagen watch Order No: W256417 today. Mesh Band is too long for me. I do not understand step 2 of instructions Ray Reeves
Ajusting the Clasp - Skagen signature mesh bands are easily adjustable in just three simple steps:
LIFT - SHIFT - PRESS Lift the slotted clasp, Shift the adjustable buckle to the desired position (make sure the clasp is set in one of the indentations on teh back of the band), Press the slotted clasp closed.
Aug 18, 2010 | Skagen Watches
Hi. I've got a Grenen mesh watch band and need to move the clasp mechanism further down on it to make it tighter, but I can't figure out how to loosen it to move it. Can you help?
Grenen watches are made by Skagen exclusively for Kohl's. Here is the link to the their website instructions for watch band adjustment.
http://www.skagen.com/service/watchInstructions.fx#adjustment
Apr 11, 2010 | Watches
I just bought a skagen stainless steel mesh band watch. I am trying to adjust the band to make it shorter. I have the piece the moves open, but I cannot figure out how to get it shut again.
your watch has the skagen signature mesh band. its actually very easy to adjust once you figure it out all you need is a small screwdriver.
Dec 21, 2009 | Skagen Signature Mesh watch
Lost clasp to my new watch. where can I get one?
Skagen is very good about doing repairs and very reasonably priced for a replacement clasp Send your watch directly to them. Because of the mesh band on most of their watches a 3rd party repair shop will only send it to them and end up costing you more money and more time.
Here is the repair form-
http://www.skagen.com/content/securePdf/SK_Watch.pdf
Sep 24, 2009 | Skagen Watches
Defective watch band clasp for Skagen #M228BB
some of these clasps are a pain. but keep trying it will clasp, slide it back and forth slightly while applying some pressure you will feel a little difference then snap it into place. there are only certain spots on the band where you can clasp it. where you are trying may just not have an indention.
Aug 25, 2009 | Skagen 355LGSC Wrist Watch
How to fasten a Skagen watch?
Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
Hope this one helps.
May 16, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
CLASP BROKEN ON A WATCH Skagen 233XSSS
$ 4.00 for skagen will send you a new clasp. but if the clasp is just open you can close it by applying pressure to the the hinged piece if its stubborn move it back and forth a little until it hits a grove.
http://www.skagen.com/service/home.fx
Nov 06, 2008 | Skagen 358SSSD Wristwatch
Skagen Slimline Mesh 358SGS Wrist Watch Logo
403 people viewed this question
Top Skagen Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
