Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
SPA2102, dial-tone time too short.
With mySPA2102, when I take the phone off-hook, I only get dial-tone for about 3 seconds. How do I increase this to about 10 seconds?
  • afas6566 Dec 16, 2009
    The problem turned out to be a Null Entry in the Dial Plan .....||..... so that the Short Interdigit Timer was activated at pick up and timed out after 3 seconds.
  • afas6566 Dec 19, 2009
    Problem turned out to be a null dial plan entry ...||...
    This meant that the dial timer was started by going off-hook and timed out after the inter-digit default time of 3 seconds. The time could be increased by increasing the Sn value but the solution was to remove the error in the dial-plan.
  • 36 Answers
The off hook timer is part of the dial plan, for instance, prepend "P10 | " to your dial plan to get a 10 sec delay. (pg 67 in the Cisco admin manual - section titled [u]Dial Plan Timer (Off-Hook Timer)[/u]
If you don't have an admin guide, google for ATA_AG_V3_200809_AdminGuide.pdf. Very useful if you need to sort something like this out.
Posted on Dec 14, 2009
AVAYA Merlin Magix phone system powers on, all phones have blank display but have message light blinking, no dial-tone, key press = no sound, adjust volume rings phone and displays on screen.
if you have it plugged into an outside line and do not have a dial tone call your phone company .but when buying stuff at an auction , well you get what you got even if it's old and none working
Feb 21, 2016 | Lands Phones
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
HAVE NO DIAL TONE SOUNDS LIKE AN OPEN LINE
your service is hooked up? do you have access to your phone box? House or apartment? can you trace the lines? if you have access to the phone box, you can open it up and plug a phone directly into it to test.
Jul 23, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
The phones worked last night, this morning nothing
If the phone rings but no dial tone, possible phone unit is faulty. I suggest to try a different phone unit to verify if it's faulty. If the other phone isn't working too, then report the issue to your phone provider.
Jun 10, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
No dial tone
Please disconnect your cordless phones from telephone jacks throughout the home. The "line in use" is say that you have a short on the line, or a phone off the hook. So disconnect lines, then replug 1 corded phone in to check for dial tone. If working, continue to plug in 1 phone at a time(rechecking working one each time) to find the equipment that is causing you heartache.
Apr 21, 2009 | Uniden Cordless Phone
Linksys Router Issue
My VOIP Adapter is lock I can't reach the web page
Jan 09, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
My phone has no dial tone.
Check if the cordless works on a normal telephone line,Plug in another instrument to see if you get dial tone,light.
That's it you should know what is causing the problem.
Samir
Dec 27, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
No dial tone
the power supply of your phone is shorted,you need to coldsolder the components of your pcd.
Apr 05, 2008 | Uniden Cordless Phone
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
797 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
