Question about Freezers
Need a freezer room electrical diagram - Freezers
    Problem Solver:
  • 5 Answers
Please give a model name or describe your freezer if it is a electronically controlled or mechanically controlled
Posted on Sep 09, 2009
The freezer alarm won't go off.
Possibly a problem with one of the components in the automatic defrost system in the freezer then.. this is the only reason why the alarm would keep sounding. Perhaps some of the moisture from the defrost has gotten in and damaged the electricals somehow. It might be worth it to store your freezer contents elsewhere and completely defrost the freezer and then heat the inside cabinet up with a hair dryer or something similar. This will dry out the cabinet and the electrical components. Once the freezer has warmed up let it stand for as long as possible with the doors open so that it reaches room temperature and then close the doors and switch back on. If this doesn't work you probably need a service engineer visit.
Oct 16, 2014 | Bosch Freezers
Viking professional defrost cycles
Check the rubber seal inside/around the door. I bet you have a tear or piece of seal that isn't making a solid fit and it's allowing (warm) room air into you freezer. This moist room air will either turn to water droplets and builds up to enough droplets to form puddles in the bottom of the freezer, or it freezes into a blob of ice around the door seal and this allows warm room air into the freezer. Otherwise you need an Appliance Tech to check the Freon refrigerant level. Most times its the door seal causing this problem.
Jun 08, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer temp keeps dropping despite putting on superfreeze switch. What might the problem be?
I own an Imperial freezer and it has a superfreeze switch. The schematic electrical diagram on my freezer shows that the superfreeze switch when activated, bypasses the temperature control thermostat and keeps operating the compressor motor non stop. Try switching the superfreeze to off after you reach your desired freezer temperature.
Aug 28, 2011 | Miele 4.2 cu. ft. / 119 liter Upright...
I'd like a electric diagram please, thank you.
What do you need to know. True does not allow this to be down loaded, they want a sales rep to call.
Nov 14, 2010 | True 49 cu. ft. / 1388 liter Commercial...
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
New freezer
Hi
No it shouldn't make the room cold except if you open it and cool air rushes out.
In fact it normally makes the room it is in hot.
Thank you for visiting fixya
Feb 27, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My chest freezer (a Kelvinator) runs, but does not get cold. The motor is clearly trying to run, but does not lower the temp beyond room temperature. There is a vague smell of burning when I leave it...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 09, 2010 | GE 13.7 cu. ft. General Electric Upright...
Fridge freezer is not workink,light is on freezer but no sound,freezer is in a cold room is it possible the room is to cold and problem with thermostate?
It could be a compressor problem, or the cold control. If your room is above freezing, the freezer should still run.
Jan 07, 2010 | Freezers
Frigidaire mod.# FFU20F9GW5
You have problem stil problem I thik its electrical you can send me copy of electric diagram to may email I can check for you and give posiable solution.
may email is : czesiek1948@op.pl
Nov 03, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
369 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
