Question about Uniden Cordless Phone
Can I use a 2.4 volt 800mAh battery in place of a 2.4 volt 650mAh battery in my cordless phone ?
  • Uniden Master
  • 8,046 Answers
If it fits snugly in the compartment, and electrical contact is made you sure can use it. But it will last less: Same as filling your car-tank 13/16.
Hope it helps.
Posted on Sep 09, 2009
How do I get replacement batteries?
ebay and Amazon are good places to find replacement batteries of all sorts but if you have a local camera shop I am sure they would appreciate your business. Local shops have a hard time these days and if they don't get used they are soon gone forever...
Oct 17, 2015 | Cameras
My cordless phone Gigaset A49H is working well. I need to replace battery. Can I use AAA Ni-MH 900mAh 2V battery
if the volts of the old batery is the same with the new u can use it...no matters if the old battery was from lithion only or nikelioum / kadmium . u can use nikelium/magnisium batery too all rechargable are (sry for bad english)
Sep 28, 2015 | Siemens Gigaset A49h Cordless Phone...
Can 1.2Vlt 800 mAh battery 1.2 volts instead of 630 mAh battery used in this device? ..
Hi
There should be no problem at all. The designations you show are both for 1.2 volts. The mAh specification refers purely to the capability of the rechargeable to deliver current over a period of time. 800 mAh will deliver 800mA for 1 hour or 400mA for 2 hours. Hence the 630mAh battery under fully charged condition will not last as long as the fully charged 800mAh battery when supplying the same current in the same application.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 30, 2014 | Cameras
Can replacing 800mah cell phone battery with 1000 or 1300 mah battery increase talktime? Current talktime is 180 mins
Yes you can provided the battery is the same physical size as the 800mAh battery
Jan 16, 2011 | Cell Phones
Hello i have a ge 28118 series slim dect
My phone is making a lot of noise and static on in coming call so bad I can't talk. out going I can't make. I put in the number to dial call does not go through ,but I can hear the dial tone. do I need a new battery or is there something wrong with the phone itself.
Jun 27, 2010 | Thomson GE-28115FE1 Cordless Phone
Power/data socket rattles Phone will not charge
The charge ports do break loose. If you know somebody who knows how to solder very well they can reattach it. Some times the copper PC board traces pull up with the legs of the mini USB port and need to be connected with some fine wire. This should be no problem for a decent electronice tech. Your other option is to find another phone in which to charge the battery. The battery is a BR50 and I charge them off the phone with two tiny alligator clips attached to the leads of an old charger. These are about 800mAh so a dead battery will take an hour or so to charge. The voltage of a fully charged 3.7 Volt Lithium Ion battery under no load should be about 4.05 volts. You can check with a volt meter. Removing the main board to access the charge port will require a T5 (Torx bit) screwdriver. Lift off the battery cover pry the plastic piece off the bottom and remove the screws. Then carefully pry the two flex cable connectors off from under the board. Lift it out and resolder the charge port. Repost if you are having any troubles.
Aug 20, 2009 | Motorola Mobility RAZR V3
4900 phone problems
Probably need new battery, you can get one here - IBM 4900 Cordless battery
Oct 02, 2007 | IBM 4900 4-Line Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
