Question about Lands Phones
Cant find a source for a PSU for an Amstrad Emailer EM1000UK p/n psu-em1000uk. can you help plse(key electronics dont do it any more
I will monitor ebay and preloved. thanks anyway
Posted on Sep 14, 2009
What i was after was a manual for amstrad emailer plus phone em 2001
Dear Brian Clarke,
Here is the link for the user manual that you require.
http://www.amstrad.com/emailer_faq/emp_auk/index.html
Or you can try
http://www.amstrad.com/emailer_faq/user_guides/index.html
I hope that this is the fixya for you and I look forward to hearing how you get on with this query.
Yours sincerely
Ouszen
Feb 07, 2012 | Cell Phones
Tip
Where can I buy parts for my Amstrad e-m@iler communicator centre
This website http://secure.key-electronics.co.uk is still operational so you can see what is available but the contact and checkout don't work.
Key Electronics are now trading as ATM Contracts from the same office
ATM Contracts,
Halifax,
Tel :01422 204010
Fax: 01422 263224
They can supply each of the following for both the E-m@iler and the E-m@iler Plus - Model Number EM2001
  • 28V 280mA PSU - Double Insulated £8.99 inc VAT P+P
  • Pocket Docket £19.99 inc VAT P+P
  • User Manual £7.99 inc VAT P+P
  • Mailboard for Internet £16.99 inc VAT P+P
  • Telephone Handset £6.99 inc VAT P+P
Hope this helps
on May 10, 2010 | Lands Phones
NO Post test beep.- no boot screen
Could be a dead PSU, mother board or CPU to me.
First check the power source, are all connections good and switches on.
Assuming so, are there any led's lit anywhere on the tower when you turn it on or any fans turning other than the PSU fan.
If there are no fans, including the PSU, then the PSU has failed, if there are fans and led's lit then turn it off, remove power source, remove the cover and check whether the PSU is properly connected to the mother board properly (Large multi-pin plug) if it is connected properly,
After this, you need proper test equipment.
Apr 15, 2011 | Gateway GM5094E PC Desktop
Power LED is On but system doesnot start ?
hello, I have a solution for u i think it may help for u.
your problem is:
When u press the start button... the power LED comes on but there is no POST beep or BIOS screen or boot up. The SMPS fan and Processor fans also dont come on at all. there is a small LED next to the SMPS plug on the motherboard that does light up when the system is connected to a power source.
Part of the system configuration is the kind of PSU you have in your system.
SOLUTION IS
So, what kind of PSU?
Try to borrow a known good PSU. Or better yet, see if you can test your PSU in another working system. If you cannot do that, try to borrow a DMM to measure the voltages. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead.
Jul 01, 2010 | ASUS P4P800 SE (890552603657) Motherboard
How do i read emails on my amstrad emailer plus phone
Press and hold down the email button. I found their website that also has the complete user guide if you need it.
Please vote "Yes" for me!
Aug 17, 2009 | Lands Phones
My Amstrad Emailer Phone is displaying,hold down Emailer button to restore servies. Why
I've had 3 of these phones and I can tell you that if the phone is unable to make regular contact with its system provider, then it will display what you are seeing on its screen. I got fed up with paying for the phone to make daily checks to see if you have any e-mails so asked BT to stop the phone from making contact with headquarters so to speak. This was duly done and it was great for about 6 months, but because the phone could no longer make contact with headquarters it simply died. They get you one way or another. If you want to pay for it to check for e-mails each day then it's the best phone around. I've tried loads since but am now going back to my Amstrad and will have to pay for its daily checks.
Hope this helps. Mike.
Jan 12, 2009 | Lands Phones
Psu
usually any PSU will fit as long as you dont have a odd case. you can even take out ur old PSU take it to a best buy, circut city, and fry's electronics and ask them for n higher watt of the PSU u already have.
Oct 17, 2008 | E-Machines Computers & Internet
No power
press the num lock key light .....
if the light doesn't blink Ram is the fault...
Remove the Ram and Take white Eraser and clean Ram pins and
fix the ram .. Mostly it will work....
Mar 11, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Repair psu for gx280
I have had several issues with this same problem, you may need a new power supply, because your old one may be failing and may need replacement.
My solution to this problem is that you may need to buy a need psu. I recommend either calling dell or buy a new psu.
Nov 12, 2007 | Dell OptiPlex GX280 PC Desktop
Lands Phones Logo
73 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
