Question about Epson H6000II Thermal Printer
Epson TM H6000II user interaction required
I'm an Artist trying to run a Epson TM H6000II from a PC to print a bitmap jpeg file as a thermal receipt, I want to produce the same receipt hundreds of times. I have downloaded the drivers and they appear in the print options as expected but they say, "user interaction required" and communication error. The printer can run a test and is working fine, it just can't seem to get recognised by the computer? The printer I have has no USB port. I'm using my friends PC as I usually use mac but there are no drivers at all for the TM H6000II for mac, so I'm really not used to PC's. Is there a simple way to do this?
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Jan 27, 2016 | Epson T70II - SPACE-SAVING - PUSB & USB -...
How to repair no print of pos printer epson tm t88iv?
did you try the basics cleaning heads , running test setup for the dot matrix printout out , changing ink sometimes ne packages sold are garbage.
Sep 05, 2014 | Epson Tm-t88iv Black Thermal Receipt...
My Clarion application sends codes directly to the (TM-H6000II) printer. I need to print in Hebrew but the printer seems to insist on Greek (I think!). I added the following code to the printer start: ...
This most likely requires that you get the Hebrew Font set from the Manufacturer and install it in the Printer Firm ware or update the Hebrew Font Set in your computer software. Either should resolve your problem. The printing that you currently see is, without actually seeing it, the result of the printer trying to print character codes that it does not recognize. I would try updating the Firmware in your printer first then if that failed update the Hebrew Font codes and character set and install that. Epson should have the download on their website. The information you need for the software Font download will depend on what software you are using.
Aug 31, 2010 | Epson TM-H60000II Thermal Printer
Epson tm-t88II prints the second copy after i restart the pc
This sounds like its a problem with your EPOS software rather than the printer - contact your EPOS provider.
Dec 29, 2009 | Epson TM-T88III Thermal Printer
Error light on a Tm-H6000II
Whats the pattern of the blinking light? can you pls describe...
what type of interface are you using, USB, SERIAL, PARALLEL, ETHERNET?
Apr 30, 2008 | Epson TM-H60000II Thermal Printer
Epson H6000II Thermal Printer Logo
243 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
