Question about Vehicle Parts & Accessories
Aolin car alarm wireing - Vehicle Parts & Accessories
2 Suggested Answers
SOURCE: car Alarm User Manual aolin al 838
I have steel mate car alarm system 838, it locked my doors and I cnat open them.
can you help
thanks
jose
Posted on Apr 08, 2011
Ca5050 uninstall
If you didn't remove the alarm "brains" under the ignition, your car is still being protected by the alarm. It is acting as a cut-off switch and will not let the car start. This can be resolved by taking the wiring and alarm relay with brains out. To do this look under steering column for the wires that are comming from the ignition, then which wire is going to your alarm light. That is the wire or wires that need to be removed and rewire the direct wires for ignition. Be sure to get all alarm system wires and components under dash out. From there you just wire the original wiring back together and should start car. If not, make sure your battery is not dead. The alarm can drain car battery if a relay is not working.
Sep 02, 2012 | Cars & Trucks
Disable car alarm
Instructions
Turn off your car engine and take the keys out of the ignition.
Set a flashlight pointing up, under the steering wheel. You need to be able to see the wiring above the brakes and gas pedal.
Locate the alarm box in the steering cavity. The box is usually a small, rectangular box with the brand of your alarm printed on it.
Feel around the box for the wires connecting it to your car's circuitry. Gently pull the wires loose to disconnect the alarm from the car.
Pull the alarm box out of the car and push the wires back into the steering cavity. If the box does not come out easily, check and make sure all of the wires are disconnected.
Jul 22, 2012 | 2005 Saturn VUE
I WANT TO FIX PRESTIGE CAR ALARM IN THE CAR' AND HOW TO CONECT THE WIRES
Below is a fast installation guide for most car alarm systems. Refer to your manual were needed. Car alarms can be hard to set up and include bands of wiring and sensing elements to instal. Take it step by step and taking after the operating instructions cautiously.
Steps to installing a car alarm system.
1. Mount the siren to a solid surface under the hood. Make sure that you point the horn of the siren toward the ground so that moisture won't affect the sound or horn.
2. Drill a hole through a rubber grommet in the firewall of the car and feed the sirens wire through the hole into the passenger compartment of the car.
3. Feed the power wire through the same hole on the passenger side. Make sure there is enough slack to reach the car's battery. 4. Connect the alarm's power wire to the battery.
5. Put a fuse on the power wire next to the battery.
6. Mount the shock sensor as described in the car alarm's manual.
7. Drill holes in the dash were you will want to place the LED status indicator. Feed the LED's wire through the hole and place the double-sided mounting tape to the back of the LED and place it over the hole in the dash.
8. Find the wires that work the car's power door locks.
9. Connect the door-lock relay to the lock/unlock wires and connect the alarm wire to the relay in the manner described by the tech advisor. 10. Locate the wire that works the courtesy light if the alarm has current sensing.
11. Connect the current sensing line from the alarm to the courtesy light wire.
12. Locate the factory door trigger if the alarm does not have current or voltage sensing.
13. Connect the factory door trigger to the alarm.
14. Locate the starter wire on the steering column below the starter switch. Cut the line and connect the starter disable relay. Connect the starter disable wire from the alarm to the relay.
15. Mount the valet switch somewhere under the dash.
16. Connect all the wires to the proper inputs and outputs of the alarm.
17. Find a sturdy surface under the dash and mount the module under the dash.
18. Use tie wraps to secure the wires of the harness and mount it under the dash.
19. Arm the alarm and test. Adjust the sensitivity as needed.
Feb 17, 2011 | 1999 Nissan Pathfinder
MY CAR WONT START BECAUSE IN AFTER MARKET ALARM. hOW DO i BYPASS THE ALARM TO START THE CAR
I've ran into this problem myself, if you're not confident with doing some wiring you probably should not be doing this. This will probably take 1 to 3 hours to do this. If you can get a wiring diagram that showed how the alarm was originally installed. If not find the alarm probably underneath the dashboard, the alarm wires will problem be smaller than a wiring that is in your car. When removing the alarm think of it as this way, someone cut into the middle of your wiring harness and put a alarm in. Would you need to do is remove the alarm and splice the cut wires back together. Instead of removing the alarm all at once try disconnecting one wire in a time and finding its mate. The wires or color coded. For example, black with an orange tracer. This would mean it's a black wire with an orange line on it. If you're not sure look at a wiring diagram splicing the wrong wires together could cause your car not to function properly or damage it. Before you start this make sure you disconnect the battery also. Good luck.
Jul 18, 2010 | 1998 Ford Mustang
Car wont start after both alarms were removed
Try to remove the After Market alarm only. The other might be the FACTORY alarm. Might want to leave the factory one in the vehicle.
Mar 17, 2010 | 1997 Honda Civic
Car alarm going off after replace positive cable
If you do not have the remote control for the alarm (which can sometimes be purchased on ebay) You will have to uninstall the alarm.
The alarm is wired between the ignition coil wire coming from the ignition switch if the car is turning over and just wont start.
This can be complicated because of the amount of wiring, You have to cut the alarm wires out 1 at a time and match the cars wires back together.
I just did this for someone on a toyota recently and you really have to pay attention or put a peice of tape on each wire writing the color for example(white wire with rd stripe or white wire with red stripe ect.)
I hope this helps you,
Please rate me if this was helpful,
ETRONIC
Mar 14, 2010 | 1994 Saab 9000
I have S 430 2002. Just after few minutes the car alarm is on or lock the car, the driver side light keeps blinking
More than likely it's a botched alarm install. There are several sitches that control the overhead lamp inside your car, as well these wires need to get thier elecrical current from the battery. There are several wire " clusters " behind your dash panel, and more than likely, when the alarm was install after-market, the installer wired the alarms " armed " signal lead to the wrong wire behind your dash, or in the fuse box itself (i've seen some rediculouse wiring jobs)
Your best solution is to find out the exact model of alarm that was installed, and try to obtain the installation documentation, as well as get the manual for your car, and check that the woring of your alarm is correct for your model / make / year of car.
I'll almost bet you money, it will be as simple as clipping one wire, and wiring it to the correct wire.
May 29, 2009 | 2002 Mercedes-Benz S-Class
Car Alarm User Manual aolin al 838
can you help
thanks
jose
Mar 24, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
526 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
