Question about Cycling
Bicycle brake screech
Bicycle caliper brake screech
    Problem Solver:
  • 6 Answers
Most cases of screeching rim brakes are due to poor brake block set-up.
Set the brake blocks so that the front of the blocks contacts the rim just before the rest of the block. You can do this by placing a thin piece of card between the back of the block and the rim when positioning the block.
Visit You Tube and type in "set up bicycle brake blocks" to see a variety of helpful videos. The ones from GCN are particularly useful.
Posted on May 07, 2016
  • 3 Answers
It needs a kind of greeze or oil on the parts that are screeching.
Posted on Sep 09, 2009
  • Donald Ayers-Marsh May 07, 2016
    No, that's wrong. The last thing one should put on brake shoes (which are always what screeches) is any type of lubricant. I should add that in addition to "toe in" mentioned above brakes can squeak due to hardened brake shoes/pads (the proper term, not blocks) loose brake pivots or contaminants in the pads or on the rim.
  • Geoff White
    Geoff White May 07, 2016
    Agree with Don, you don't put grease or oil on your brakes.
Cant get brakes to fit
Do you mean that the brake bolts will not fit through the forks, or that the brake calipers are too deep / shallow for the brake blocks to meet the rims ? If the latter, you will need to exchange them for brake calipers of a shallower or deeper drop.
Jan 18, 2016 | Cycling
Intermittant screeching noise by rear passenger side
Your description makes me worry. If you have a strange, unknown screeching noise coming from the right rear wheel and now there is a burning smell. Please stop using it and have it looked at as soon as possible. There are a few things that could be the cause of these symptoms. Wheel bearing failure, seized brake caliper or frozen caliper sliders, damaged brake line, seized E-brake cable, or improperly installed brake-pads. In any case, if you continue to drive this car, with these symptoms. You may cause a break-down (requiring a tow), or cause a fire. Let me know if I can answer any other questions or how the repair goes, good luck.
Apr 01, 2014 | 2005 Chevrolet Malibu Maxx
Screeching drivers side brakes
you sure it's a screeching on the brakes? if so the pads may be wearing down unevenly and you may need to get new calipers installed, if it is a grinding noise, have the wheen bearing/CV Axle checked out
Dec 11, 2011 | Toyota Cars & Trucks
Screeching noise occurs when I brake. I've just
this problem occurs on many rim brakes this means that the brake are pads which make contact with the rims of your wheels the problem is not that there is oil or grease but that the brake pads vibrate when you apply pressure this is one of those situations where the rim could use just a little oil a way of possibly reducing the noise is to have either the front or back section of the brake pads touch first, thus reducing the vibration
Feb 24, 2011 | Cycling
Cannot install front tire because the front brake calipers will not open up
With the tire not installed, push the brake calipers together and release the brake cable from one side, this should allow the calipers to spread fully. Now, install the wheel/tire into the calipers. Next, move the tire/wheel assembly around to get enough play to squeeze the calipers together and reinstall the cable in it's proper mounting location. Last, mount the wheel and tighten the axle.
Gary
Dec 26, 2010 | Pit SSR 110CC Pro Beginner Bike
Jammed Avid Juicy 5 brake piston
Sounds like you need to strip down the caliper and clean it out im afraid. How about trying a LBS?
(usually its caused by a dry seal and the piston has to be forced out by putting an air line onto the caliper bleed nipple and blasting air into it to force it out - *be careful if trying this!!**)
Jan 07, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid Juicy five system leaking fluid
Your brake failed and you need to take it to a good bicycle repair shop in your area. Hydraulic brakes on bicycles are not easy to self service as you need specialized tools and the proper replacement parts.
Aug 23, 2009 | Avid Code Hydraulic Disc Brake
Cycling Logo
262 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
