Question about Jane Powertwin - Silver Jogger Stroller
New brake pad
I have recently purchased a powertwin off ebay but the brake doesnt work (the lever bit does nothing) i have been told i need to get a new brake pad but i dont know where to start looking for one. Help! Thanks
  • 419 Answers
You should be able to get some help by contacting www.johnstonprams.co.uk. Ensure that you know what model this is, whether this is a Pro or Non-Pro version.
I hope this helps.
Posted on Sep 14, 2009
I recently just bought an 08 chevy silverado ltz and had my emergency break on, did not know to release it there is a lever to pull under the steering wheel. I thought it was like my dads tundra and m
Do you have a question? or are you making a statement? Did you drive for quite a bit while leaving the e-brake engaged? if so you will probably need a new set of pads and possibly new rotors if they got too overheated.
Nov 13, 2014 | Cars & Trucks
Change front brake pads, 2002 FXD
For 2002 DYNA to replace front brake pads FIRST remove the front master cylinder reservoir cap because as the pistons are pushed back into the caliper the fluid level may rise and you will need to see this and may have to remove some excess fluid, the3n loosen but do not remove both (12 pt/0.25 in.) pad pins, remove both 10 mm caliper mounting bolts, detach and remove the caliper from the front forks and brake disc, pry the pads back to force all four caliper pistons fully into their bores, with the pistons retracted, remove the pad pins and brake pads. The front left, front right (if present as not present on all motorcycles) and the rear brake calipers use the same exact brake pad set. On the right side of the vehicle, the pad with the two tabs installs on the inboard side of the caliper and on the left side the pad with the two tabs installs on the outboard side of the caliper. Install new brakepads into caliper with the curved portion of the pad facing the rear of the motorcycle, loosely install the pad pins until you hear an audible click, attach the caliper to the front fork, on models with dual front calipers check the alignment of the brake discs to the calipers. Loosen the axle pinch bolt nuts, tighten the axle nut to the proper torque, insert a 7/16 in. drill bit through the hole in the axle as far as it will go so that the contact point will have the edge of the drill bit touching the edge of the fork leg, place the caliper over the brake disc with the bleeder valve facing upwards, loosely install the long 12 pt/10 mm mounting bolt into the top hole on the fork leg, install the short 12 pt/10 mm mounting bolt into the bottom hole on the fork leg, tighten the bottom mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten the top mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten both pad pins to 180-200 in-lbs (20.3-22.6 Nm)., on models with dual front calipers, tighten the pinch bolt nuts while holding the slider against the 7/16 drill bit if necessary, remove the drill bit, pump the brake hand lever to move the pistons out until they contact both brake pads, verify the piston location against the pads and if the front wheel is off the ground, rotate it to check for excessive brake pad drag, check the brake fluid level in the master cylinder and fill it to the proper level if necessary using D.O.T. 5 SILICONE BRAKE FLUID, install the master cylinder reservoir cap and tighten its cap screws to 6-8 in-lbs (0.7-0.9 Nm), turn ignition switch ON pump the brake hand lever to verify operation of the brake lamp, test the brakes, test ride the motorcycle and if the brakes feel soft or spongy, bleed the system until you get a firm/hard brake lever and avoid making hard stops for the first 100 miles (160 km) to allow the new brake pads to become conditioned to the brake disc(s).
May 13, 2014 | Harley Davidson FXD Dyna Super Glide...
Having problem with my front brake for Yamaha R1 , the brake pads are locking while am riding n it happens after about a mile. The problem started after replacing a brake lever . Any solution ?
OK.... The problem is your brake lever. There is nothing wrong with your braking system, Master Cylinder is fine, pads are fine, fluid is fine, everything is fine. Replace that brake lever with the original one your took off, if not, it will cost you your life. I know I was almost killed due to the wrong brake lever. Everything on the new lever looks right. Right? Same, pin hole size, the plunger seems to fit perfect, the brake light switch flange, it fits, appears to work fine, doesn't bind.. Then wham!! You lock up. DO NOT RIDE WITH THAT NEW LEVER ON.. No matter how expensive it was. Live with the Stock one until you can be sure that the next one you buy is absolutely and irrevically safe to ride with. This MOD is not worth your life. FYI, my lock up occurred in the dark, US 101, lane three, 80mph. 80mph to 0mph in 1 second flat. Bike did not flip just came to a massive stop. I will spare you the "Most frightening 2 minutes of my life". I have 26 years of riding experience, and one stupid mod nearly took my life, and my bike, and more importantly, could have taken someone else's life, or scarred them for life had they hit me... Just saying'.
Happy safe riding. Phil.
Feb 23, 2012 | 2008 Yamaha YZF-R1
How do i change front brake pads on my 2002 fxd super glide
emove the front master cylinder reservoir cap because as the pistons are pushed back into the caliper the fluid level may rise and you will need to see this and may have to remove some excess fluid, the3n loosen but do not remove both (12 pt/0.25 in.) pad pins, remove both 10 mm caliper mounting bolts, detach and remove the caliper from the front forks and brake disc, pry the pads back to force all four caliper pistons fully into their bores, with the pistons retracted, remove the pad pins and brake pads. The front left, front right (if present as not present on all motorcycles) and the rear brake calipers use the same exact brake pad set. On the right side of the vehicle, the pad with the two tabs installs on the inboard side of the caliper and on the left side the pad with the two tabs installs on the outboard side of the caliper. Install new brake pads into caliper with the curved portion of the pad facing the rear of the motorcycle, loosely install the pad pins until you hear an audible click, attach the caliper to the front fork, on models with dual front calipers check the alignment of the brake discs to the calipers. Loosen the axle pinch bolt nuts, tighten the axle nut to the proper torque, insert a 7/16 in. drill bit through the hole in the axle as far as it will go so that the contact point will have the edge of the drill bit touching the edge of the fork leg, place the caliper over the brake disc with the bleeder valve facing upwards, loosely install the long 12 pt/10 mm mounting bolt into the top hole on the fork leg, install the short 12 pt/10 mm mounting bolt into the bottom hole on the fork leg, tighten the bottom mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten the top mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten both pad pins to 180-200 in-lbs (20.3-22.6 Nm)., on models with dual front calipers, tighten the pinch bolt nuts while holding the slider against the 7/16 drill bit if necessary, remove the drill bit, pump the brake hand lever to move the pistons out until they contact both brake pads, verify the piston location against the pads and if the front wheel is off the ground, rotate it to check for excessive brake pad drag, check the brake fluid level in the master cylinder and fill it to the proper level if necessary using D.O.T. 5 SILICONE BRAKE FLUID, install the master cylinder reservoir cap and tighten its cap screws to 6-8 in-lbs (0.7-0.9 Nm), turn ignition switch ON pump the brake hand lever to verify operation of the brake lamp, test the brakes, test ride the motorcycle and if the brakes feel soft or spongy, bleed the system until you get a firm/hard brake lever and avoid making hard stops for the first 100 miles (160 km) to allow the new brake pads to become conditioned to the brake disc(s
Aug 12, 2011 | 2002 Harley Davidson FXD Dyna Super Glide
I can squeeze my front brake lever all the way in. I need to pump it to get my brake to work. Do I have bleed my line out? My digital Rpm goes from 3 to 7 and back to 0 it doesnt work anymore. Is...
To address your brake lever, could be air in the line low fluid level, or could be a bad plunger seal in your lever. Check fluid level first. If you recently changed the brake pads, bleed the brakes. If this does not help, then check out bikebandit.com for OEM parts. you should be able to buy the little rubber seal that attaches to the lever. Look at the schematics at bikebandit, it will be clear.
Nov 22, 2010 | 2001 Yamaha YZF-R1
Back tyre
If you visit www.johnstonprams.co.uk you will be able to purchase this part.
I hope this helps.
Nov 11, 2009 | Jane Powertwin Azulon Stroller
Rear Disc brake is rubbingke
I had the same problem with my Hope mono-mini.
I took it into a shop and the guy showed my ruffly what to do.
On the side that the disk is rubbing you need to put a spacer on the bolt between the brake mount and the bike's mount.
If done correctly (or understood what i meant) it will pull the pad away from the disk a little bit and it will stop rubbing.
Hope it helps
Ed
Feb 01, 2009 | RTO Hope Tech X2 Mtb Mountain Bike Disc...
Front brakes binding and grinding
Sounds like your brake calibers are sticking. Get new ones and new pads. You probably should get new rotors also because with the dragging calibers they most likely got hot and are warped. Search on ebay and www.rockauto.com . I personally use power stop drilled and slotted rotors with mid grade pads. You can probably get a whole kit.
Oct 22, 2017 | 2000 Ford Windstar
Jane Powertwin - Silver Jogger Stroller Logo
78 people viewed this question
Top Jane Baby Gear Experts
D. E. Hev
NOEL
NOEL
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
