Question about Polaroid PoGo Digital Photo Printer
Cannot sent wireless or blue tooth to pogo - Polaroid PoGo Digital Photo Printer
Login to pogo
If you account is linked to an e-mail address just go on Pogo and click on sign in then click on forgot password or screen name, the nxt step will be to enter your e-mail address and wait 20second to 1minute and a link from pogo with be sent to you. They they might send you a temporary password or a link to change your password. if they sent you a temporary password, sign in pogo and go to your acc settings and change
Nov 22, 2016 | Computers & Internet
USING SOUND BAR FOR BLOWN SPEAKER ON TV
If you use Blue Tooth, wires are not needed.
Press the manual Mode button to find blue tooth mode. Green light will display. Blue Tooth is a general signal sent out. There is no specific setting for TV.
If your TV is sending out a Blue Tooth signal, it should find the speaker automatically. http://www.ematic.us/sites/default/files/ESB212_Manual_01_0.pdf
Check your TV's Blue Tooth settings and have it scan. Default password/code for the sound bar is 0000.
Also check your remote batteries. Sometimes they are installed backwards by the factory so they won't go dead.
Mar 22, 2016 | Ematic ESB212 Wireless SoundBar with...
Please sent me acer 5734z blue tooth driver
http://support.acer.com/us/en/product/default.aspx?modelId=2235
There is the list of drivers available for your Acer model. I am not sure about a bluetooth driver, but they have wireless drivers which I think you are talking about.
Hope this helps!
Apr 26, 2011 | Computers & Internet
I have HP Pavilion DV6 model no WW146AV.How to activate bluetooth in this model
If your particular model of HP has the blue tooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the blue tooth, as well as the wireless LAN. A blue tooth icon should appear in your task bar near the clock when blue tooth is turned on. ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
Mar 21, 2011 | HEWLETT-PACKARD Hewlett Packard Hp...
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Windows vista which USB cable do I need to use a
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usb blue-tooth adapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
If this information was useful please click
Aug 16, 2009 | Trust (14694) Keypad, Mouse
Any way to connect to a PC with Blue Tooth
No printer driver needed. Just establish a Bluetooth connection between the PC and the PoGo, then send the file to the PoGo using Explorer. In Windows you can right click on the JPEG file and send to - bluetooth device.
Feb 15, 2009 | Polaroid PoGo Digital Photo Printer
Blue tooth erro
this means that phone need a relacment for Blutooth's Circuit/Chip.
its not an esay task beleive me.
ple rate this post as good as u can
Oct 08, 2008 | Nokia 9300 Handheld
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
Polaroid PoGo Digital Photo Printer Logo
103 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Joseph Gallucci
Jonathon summesfield
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
