Question about HP Photosmart C5280 InkJet Printer
Hp c5280 all in one printer won't turn on when i pushh power button.the paper jam warning light is on solid but there is nothing i can see jammed and no paper stuck either.Can u suggest anything?
    Sniper:
  • 70 Answers
Check the back panel of your printer,maybe there are some small foreign object that are stuck on it.
Posted on Sep 09, 2009
Printer keeps flashing that there is a carriage jam and to clear it but there is no paper in my carriage and the printer won't print. I have looked everywhere and cannot find any paper jam.
Usually inkjet printers are dirty ones, its requires periodically service, better overhaul the printer. 85% of complaints will resolve in service level only, try it best off luck..
Sep 28, 2011 | HP Photosmart C5280 Printer
Hp c5280 - when turned on loud clicking noise where cartridges are. it says paper jam but there is no paper jam in back of printer.
if u r sure that there is no paper jammed inside then probably u will have to reset the unit and even if that doent work u will have to take it to the service center...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00909241&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3204464
follow the ablove link... make sure u do all the steps from the beginning
thanks
agnel
Mar 17, 2011 | HP Photosmart C5280 InkJet Printer
Carriage Jam
Carraige rod is the rod that holds the cartridges and moves while printing on the paper and spreads ink on the paper and if this rod is jammed it is known as carraige jam.
Please follow the below steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423360&cc=us&lc=en&dlc=en&product=3204464
Please open this link and follow the steps.
If still the issue persists, please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Thanks Bye.
Please take care and KEEP SMILING.
Apr 10, 2010 | HP Photosmart C5280 Printer
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
HP P2015 Intermittent paper jam lite on solid.
Remove the covers and thoroughly clean the inside of your printer. Vacuum it out and wipe it down. Then examine the sensors and their wiring connectors. Intermittent problems are difficult at best. I suspect a thorough cleaning will eliminate it.
Nov 09, 2009 | HP LaserJet P2015 Printer
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Paper jam when no paper has been anywhere near it, 1/2 INSTALLED
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 27, 2009 | HP Photosmart C5280 Printer
Hp 2015dn paper jam light on solid,won;t print
This is a widely known problem with this printer and means the formatter board needs to be replaced. Save yourself the cost and headache of repairing and move on. The problem initially began as a random situation where I would have to turn the printer off and back on to get it to print.This eventually progressed to the problem you all are reporting which is the amber toner and jam lights on. I replaced the formatter board on mine and after one month the problem returned with the new formatter board needing replaced as well.
Of course, HP acts as if they've never heard of the problem. This company's integrity and quality has gone from number 1 to dead last.
Dec 09, 2008 | Office Equipment & Supplies
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Paper Jam
Just check the rollers for debris or any tiny piece of paper. Sometimes using refilled cartridges also can cause this error. Should that not work, you could try a hard reset: unplug printer from pc and mains. wait about 10-15 minutes and while holding down the power button, connect to mains and tho pc. Hopefully that should work.
May 11, 2008 | HP Photosmart C5280 Printer
HP Photosmart C5280 InkJet Printer Logo
186 people viewed this question
Seeker5211
Seeker5211
