Question about Dell Vostro 200 Mini Tower With 20" Flat Panel Monitor PC Desktop
1 beep every 3 seconds
Im a service engineer and i have a pc with the same problem powers on but wont boot gives 1 beep every 3 seconds i ve changed the power supply ram videocard disconnected all usb audio and sata and power connectors and it still does the same so its down to a board or cpu fault in my case bad news for me
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Just grasping at straws, so to speak but did you try a known good harddrive and/or flashing the BIOS?
    Problem Solver:
  • 11 Answers
This is a bios beep code I looked for you for 2 min could not locate code but you need to look for it. http://www.creatingwords.com/articles/tech/biosbeepcodeslist.htm
Could be bad ram or wrong ram. But you might be right more beep the bigger the problem. Next time count the beep does it stop?
If you can count ti try to match up on the wesite Good Luck.
Posted on Sep 09, 2009
    Genius:
  • Dell Master
  • 1,250 Answers
The system is having a problem accessing the system memory to refresh it, a problem either with the system memory or with the motherboard itself.
    Problem Solver:
  • 17 Answers
CHECK THE CPU WITH ANY OTHER RELEATED MOTHERBOARD AND CONFORM IT IN CASE IT IS OK THEN PROBLEM WITH THE MOTHERBOARD
Asrock G31M-S No Display/Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
Dec 18, 2014 | Asrock Computers & Internet
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Freezes at bios screen
im not sure about this but i think you need to replace the bios cos even tho you can get in but i will freez again and again
good luck
Oct 22, 2012 | Computers & Internet
Computer wont boot up
you need to refix the RAM sticks and restart your pc. IF the problem persists change the RAM slots and put RAM sticks one by one in different slots, then restart your pc it will work
Feb 15, 2010 | Gateway GT5220 PC Desktop
Beepcode: single beep every 2 to 3 seconds continuous
Try taking out the ram and reinserting it also anything that is in the PCI Card slots.. other solutios is take and unplug each device and see if the boot up changes it will sometimes give a read code it might help eliminate the problem
Jul 26, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
Laptop wont switch on
remove power cable, battery and all cables attached to ur laptop, then press the power on button for 10 seconds after that attach battery, whatever cables that you had disconnected, and switch on again if doesn't give display and beeps for 3 to 5 times then thats minor or may be ram problem, or if it beeps for 7 times then thats motherboard problem, take ur laptop service centre.
May 03, 2009 | Computers & Internet
No boot
Check to make sure you don't have any extra standoffs under the motherboard that may be shorting it out.
Nov 02, 2008 | Intel DG965WH Motherboard
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
Dell Vostro 200 Mini Tower With 20" Flat Panel Monitor PC Desktop Logo
641 people viewed this question
Alun Cox
