Tv wont turn on
Magnavox model no. mwc24t5b used vcr vhs tape came out ,but tv shut down and wont turn back on try every thing i really need a schematic please help . ps. i googled it and got nothing
  • 115 Answers
The lamp for the screen overheated,you will need new one its around 150 and up for the part plus labor,so do the math if its worth repairing it.if my info was of help to you please leave a comment,vote,note.thankyou
Posted on Sep 09, 2009
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Magnavox tv/dvd/vcr combo model mwc24t5b i put a tape in the vcr hit play and the tv shuts off. everything else work fine on the tv.
Usually when that happened for me, it meant that one of my small children had also put a foreign object in the slot where the VHS tape goes. Any type of obstruction will cause the VCR to jam and force the television to shut off.
May 23, 2010 | Televison & Video
Magnavox TV/DVD/VCR combo keeps turning off
So after calling a tv repair guy and listening to him tell me about how it is probably something to do with the transistor and it will cost me about 150 dollars to fix ( which I could buy a new tv for that price since it is only a 19 inch) I decided to look online at this issue of turning off after 5-10 seconds. I read about it being an issue with the VCR sensor, so I don't know about it being some LED that you have to replace because I just messed around with a VHS and moving the little white bar thingy on the right just inside the door for the VHS around a bit, and Voila it started working right again. I think maybe my son tripped something by sticking things in there and whatever I touched fixed it. So my advice is to just stick a VHS in and take it back out a few times and play with a few things inside and to the right. It didn't take long for it to work for me.
Jul 23, 2009 | Philips Magnavox 20MC4304 20 in....
May Magnavox MWC24T5B tv/vcr/dvd combo will not stay on.
I've found the center LED in the VHS player faulty with those symptoms. Change it you'll be fine. Larry
Jun 17, 2009 | Philips Televison & Video
TV SCREEN IS JUST A BLUE PICTURE,BUT HAS SOUND
Hi and welcome to FixYa,
Offhand it would appear that the VCR section of the combo unit would require a bit of cleaning. Specifically, head cleaning. The easiest approach is to use a VHS tape head cleaner.
The other post of "tv turns on then 5 seconds later shuts off" would be the auto-protect kicking in. This indicates that a likely hardware fault exists. Try to initially reset the unit by unplugging from the mains for an extended period. Otherwise it would require opening the unit for voltage measurement/diagnosis.
Pls post back updates. Good luck and thank you for using FixYa.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Magnavox VCR/DVD player CMWR 20V6
The same thing happened to me and it is the power supply. You can get a new one at parts@funaiservice.com
Nov 26, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
MAGNAVOX TV /DVD,VCR CUTS OFF
is the VCR trying to eject a tape even if there is no tape in machine. then shutting down ? if so the vcr sensors need to
be replaced
sensors avalible from funai
Jan 03, 2008 | GE 13TVR72 13 in. Combo
Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
Electro Med Services...
