Question about Dishwashers
When i switch on it does nothing ,just a noise that is pumping water out but there is no water and the machine do not start
    Problem Solver:
  • 5 Answers
Clean first the filter of the water inlet.
and if your a techy check the solenoid valve
"mechanical and Electrical"
also check if there is voltage supply in the connector of the solenoid valve if there is no supply the problem is coming from the relay of mainboard
Posted on Sep 09, 2009
  • 1 more comment
  • Nairb_is_hir Sep 09, 2009
    clean first the filter of the water inlet.
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
After starting the machine, I did not hear any water coming in and a hum coming from the back. The error code was IE. Is that the pump?
suggest you call a repair service.we do not know if you have a washing machine or a refrigerator
Feb 19, 2018 | Washing Machines
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Crosley washer fills with water than does nothing lid switch is good
Hi - Since you have already confirmed that the door lid strike is in good condition, does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Nov 19, 2012 | Washing Machines
I have an F&P MW612 washing machine that stops at the start of the spin cycle leaving water in the machine. After pushing the pause button, looking inside, closing the lid and restarting I've heard...
Something may have been stuck in the drain pump impeller creating the clanking noise. This is a serious problem that can lead to the burning out of the motor controller module, the machine's "brain". It has been found that a short circuit is imminent on a leaky drain pump which can eventually burn out the motor controller module.
Empty the machine then lay it's front on a padded floor/surface and check the drain pump including the diverter valve where both the drain pump and the recirculation pump connect from. Replace the drain pump if damaged or leaking to avoid further damage to the motor controller module.
Fault Code Reading on Fisher and Paykel Top Load Washing Machines
Aug 23, 2011 | Washing Machines
Washer filled with water and then does nothing but make a clicking noise
If it's not spinning, the transmission is bad. If it's just not emptying the water, the pump is clogged or bad.
Unless you can replace the transmission yourself, it would be a better bargain to buy a new washer.
May 03, 2009 | Washing Machines
Water not draining
your chicken wish bone may have broken your drain pump- it may have prevented the impeller to spin while the motor was on-not good. you may want to consider changing the drain pump...
Mar 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Nov 11, 2008 | Kenmore 22422 Top Load Washer
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
