HP OfficeJet k60 All-In-One InkJet Printer
Problem for HP OfficeJet k60 All-In-One InkJet Printer
When I copy or scan a picture a line is down the
By hroydell on Sep 09, 2009
When I copy or scan a picture a line is down the center of the picture
Solution #1
posted on Sep 09, 2009
Not Rated)
Shah_Sheh
Rank: Guru
Rating: 88%, 56 votes
When scanning the page it is passed over the scanner, a mark on the scanner will then be copied down the full lenght of the page. I not sure how much access to the scanner you have with this model but you need to examine the scanner for a spot of dirt/correction fluid and clean it, you may need to scratch it off with an old credit card or similar
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet k60 All-In-One
Questions and Unsolved Problems for HP OfficeJet k60 All-In-One
Do you recommend HP OfficeJet k60 All-In-One InkJet Printer?
Answer
Answer
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple... (More)
Answer
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has... (More)
Answer
How do I scan a document? I am getting a message that indicates that the options are not set.
Answer
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink.... (More)
Answer
Opened printer - pieces of paper stuck in roller in back - can't seem to open
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
