I could not use my hsc all-in-one printer with vista because driver does not supprt.It is notb being download from hp site
  • Alun Cox May 11, 2010
    Model Noumber/
Hi, i have hp laser jet 3030 all in one, i have xp cd, but i have vista 32 bit currently, i can't download drivers from hp site, upd, ftp file, why can't i download from hp site?
Have no idea why you can't download the drivers from the hp website.
I have a 3030 at home. I just downloaded the drivers. Don't forget, you
have to use the "universal drivers" for Vista and Win7.
www.hp.com. I've always had good luck and less problems with the PCL5 drivers.
Apr 13, 2011 | HP LaserJet 3030 All-In-One Printer
HP Lazerjet 3100 will not run on Vista. Has a fix been developed?
Have you tried downloading the Vista printer driver from the HP WEB site?
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Dec 02, 2010 | HP LaserJet 3100 All-In-One Printer
Pls i want driver windows vista
you can get windows vista driver from http://panasonic DP-1080p driver.com
Dec 09, 2009 | Panasonic DP-1810P Laser Printer
Printer Type-HP Deskjet 1420 can't connect.
First thing I would do is uninstall any software you have already tried to install. Then in the Control Panel, remove the printer.
Then...Go to HP supprt for your printer:
HP D1420 Support
Select Software & Driver Downloads.
Select your Operating System. (Vista)
You will then get a list of available driver/software to download. (Note that there is also a link to order a new CD if you so desire.)
Select the Basic or Full feature. (I would go Full Feature.)
Then the download page will appear. Click on the file name to download it. Select Save when you get the download window. Save it to your Desktop for ease of installation afterward. Do not Run.
Once downloaded, remove one end of the USB cable from the printer. Turn the printer ON.
Double-click the file on the desktop that you downloaded. Do not connect the USB cable until prompted by the software.
Save the Support page above to your Favorites for future use.
Thanks for using Fixya. If you have any trouble, just Comment back.
Jul 03, 2009 | HP Office Equipment & Supplies
I can not get my printer to print
Most devices will require a 'Device Driver,' which is available from the manufacturer's website.
It will be specific to your version of Windows; e.g. Windows XP, Windows 98, Windows Vista.
Also, there is no support yet for some devices in Vista.
To check your own device, google '[printer model] vista support', e.g. "HP 4100 vista supprt"
Dec 02, 2008 | Office Equipment & Supplies
Losr drivers -can not install
go to dell.com under supprt area drivers download type in your model then xp or vista then save new file to hard dirve install it double clik after done download in g ok
Oct 08, 2008 | Dell 924 All-in-One InkJet Printer
Can I get a program that will allow me to scan from my 5610 all in one to my computer Vista Home, tks
Go to the HP site(google it) then go to downloads, then drivers, then select you Printer model, then select the scanner drivers, make sure you change the operating system from windows XP to Windows vista, then download them.
should the problem persist, go to the microsoft site, in the search tab, type "HP 5610 scanner drivers for windows vista.
Jul 30, 2008 | HP Office Equipment & Supplies
MF-Jet 450 driver for Vista
O.k so you can't find the driver at philips, have you tried Microsoft itself? www.microsoft.co. supprt & downloads if still No luck a tried and tested site that has never failed me for all sorts of software & downloads is www.cnet.com still no luck /google Driver detective works well believe me!
Good Luck!
Press the Blue Button please for my FREE advice/effort,
Thank You!
Paul 'W' U.K.
Mar 27, 2008 | Philips MF-Jet 450 All-In-One InkJet...
Won't install on Vista OS
Goto the following site and download PCL5 or PCL6 driver.
Uninstall any driver used already. Plugout your printer and then Install the downloaded driver. After finishing the download connect your Printer. You must be able to print on this Printer from Windows Vista
Feb 06, 2008 | HP LaserJet P2015dn Printer
18 people viewed this question
jasbo
jasbo
