Question about HTC Touch P3450 Smartphone
Without the manual for my BH M200 HTC blue tooth, I haven't been able to push the right passcode of buttons to pair the headset with my new phone
  • 813 Answers
Try the default pair code as 0000, 00000, 00000000 or 12345. One of the above codes should work with your headset.
Posted on Sep 11, 2009
When I try to couple the BH-218 to my Garmin i press the ]as in the manual but only get voive prompt on or off, the coupling mode does not seem to function.
My guess is you don't have the headset in pairing mode. The instructions below are from the instructions for the BH-218"
Before using the headset, you must pair and connect it to a compatible phone.
1. Make sure your headset is switched off and your compatible phone is on.
2. If you've never paired the headset with a device, or you've cleared the pairings,
switch the headset on.
If you've previously paired your headset with another device, press and hold the multifunction button
for 5 seconds.
Pairing mode is switched on, and a blue indicator light starts to flash quickly.
3. Within 3 minutes, switch Bluetooth on in your phone, then set it to search for
Bluetooth devices. For details, see the user guide of the phone.
4. On your phone, select the headset from the list of found devices.
5. If asked, type in the passcode 0000.
When the headset is connected to a phone, the Bluetooth indicator light flashes
slowly.
You can pair your headset with 8 phones, but you can only connect it to 2 phones at
the same time.
With some phones, you may need to make the connection separately after pairing.
Tip: Can't connect the headset to a compatible phone? Make sure that the headset
is charged, switched on, and paired with the phone.
Jul 15, 2013 | Nokia BH-218 Bluetooth Headset
Have always used 0000 on my mobile as passcode to pair with nokia bh 212. however, for some reason, it says unable to pair, since this afternoon. pls help if there is anything else that i can...
i find out the way already as after reading its manual. You have to reset this headset by turn it off first. Then you push and hold its function button around 8~10s, you'll see the green and red indicator light alternate. Now you pair again with your phone and it works.
Sep 08, 2011 | Nokia BH-212 Bluetooth Headset
Passcode for nokia BH-104:
Hi, want to pair? Simply easy.
When you want to pair a blue tooth there are some possible steps you will need to take,like pairing and pairing with a pass code.
To make it easy you cab use the manual to know the steps in pairing the device with a phone.
You can use the below link to download the manual ::
nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-104_apac_ug_en.pdf
Hope it helped.And please to forget to rate me. Thankss
Have a nice day...
Feb 21, 2011 | Nokia Bluetooth Headset Headset
Trying to pair nokia x6 with nokia BH-214 bluetooth headset i need the code to pair them
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
Reply
Sep 15, 2010 | Nokia BH-214 Bluetooth Stereo Headset
Hi, my problem is with my nokia bh-214 headset.. when i try to connect it asks for a passcode.. i didnt get on with the unit and have tried the recomended codes like 0000, 1111, 9999, 1234, none of...
when you are pairing the head set and phone make sure the blue light is flashing on the head set witch the blue tooth put the blue tooth on the phone when asked put 0000 they should pair
the head set has to be charged to us it
Sep 07, 2010 | Nokia BH-214 Bluetooth Stereo Headset
I try to connect my HTC M200 bluethooth headset with my Samsung S-M5230 mobile. The mobile can not find the headset. I tried it with another bluethoot, and it worked. The headset also use to be working...
is this the first time that you're going to pair the phone and the headset? try to turn off both devices, turn on the blue tooth headset, try to press and hold the power button for 5 seconds until you see a solid led light on the headset, try to open the phone, open the phone's blue tooth then search the headset. If the phone is asking you to enter a code try to enter 0000.
Jul 06, 2009 | Samsung Cell Phones
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Lost HTC BH M200 Bluetooth headset manual, How do I pair it?
Hi, to pair this device first make sure it is powered off.
Then press and keep holding the power on button (large round one on the front). After a few seconds the LED will illuminate blue and then after a couple more seconds will flash red and blue. Now you should be able to pair with it.
Regards,
Nik.
Dec 14, 2008 | HTC Touch P3450 Smartphone
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
HTC Touch P3450 Smartphone Logo
614 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
