Question about Samsung ML 2010 Laser Printer
4 faint lines running vertically down the sheets of paper
Everytime I print the prints come out with vertical lines down them in the same four places again and again. These lines make slight grooves in the paper and someitmes are very dark and other times are fairly light but the indent is always there.
Can anyone help me? I thought that it may be the foam strip but I do not know how to get inside to change/clean it.
Thank you fro your help in advance.
    President:
  • Samsung Master
  • 2,022 Answers
Just open the printer cover and clean the toner with tissue paper and make sure the toner is not damage othewise you have to replace the toner.
Posted on Sep 09, 2009
Why am I getting vertical Yellow lines on my printing?
It sounds like the laser drum is damaged and not collecting toner correctly. First try cleaning the paper path with laser cleaning paper. If that doesn't sort the problem replace the drums.
Aug 09, 2014 | Ricoh Aficio SP C811DN-DL Printer
Canon image runner c5800 printing vertical lines
have you ran a test page , the test will take about 30 sheets of paper it will test everything and will correct itself
good luck
Dec 04, 2013 | Office Equipment & Supplies
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
Sharp copier, not producing clean copies
Check the fuser roller if it still has faint prints on the roller then your getting a shadow image in your prints,. Could be a bad fuser roller replace it
Mar 24, 2010 | Sharp Office Equipment & Supplies
Vertical line and five spots in every sheet of paper I print
Thats on the drum, time for a new cartridge.  The equial distance of the marks on the right side of the page point to the drum  which I presume is built into the toner cartidge.
May 30, 2009 | HP LaserJet 1012 Printer
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Dirty printing job
Are they lines from one edge to the other in a straight line. Or is it faint reprint across the page?
Thin lines would most likely be a bad drum or cleaning blade.
If it is faint reprint it is the heat roller in the fuser.
May 22, 2008 | Xerox Office Equipment & Supplies
Samsung ML 2010 Laser Printer Logo
159 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
