Sounds like one of five possible things
Bad rings
bad valve seats
intake clogging
radiator fluid leaking into piston because of bad seal or crack in head
PCV valve not working or clogged
If the smoke is white, it could be water from a leaking head gasket. Two or three hundred pounds should be a replacement cost. Check to see if the radiator (header tank) water level is slowly dropping. If the smoke is grey/black, then the piston rings or cylinder bores could have worn out, or the valve oil seals have started leaking. Try Wynns Engine oil leak stopper - £5 from auto shops. This usually greatly improves valve seal problems.
Chk your PCV valve. If faulty it will allow oil to be sucked up and burned. Its the critter stuck into the valve cover and has a rubber hose on it. Good
luck, Ned It's an easy fix and inexpensive. So not to panic.
