Question about Panasonic DVD-RV32 DVD Player
Error code h07
Put in DVD shows reading...then error code h07 then stops
  • 189 Answers
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Posted on Sep 09, 2009
When trying to play a dvd , it shows H07
Traverse unit (spindle motor & laser assembly combined) is most likely faulty. The motor part usually fails first, which stops the discs from spinning, so the inbuilt laser cannot read them, hence the error code. This can be expensive to replace.
Jan 28, 2011 | Panasonic DVD-RV32 DVD Player
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
H07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Panasonic DVD-RV32 DVD Player
DVD error HO7?
Will read dic and play movie for about 10 mins and then stop and give me the error code H07. What is this and how do I get rid of it?
Feb 01, 2009 | Panasonic sa-ht800V Home Theater Audio...
Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Panasonic DVD-RV32 DVD Player Logo
693 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
