Question about Acer Aspire 4530-5889 Notebook PC
Blue screen error
Cannot format..appear blue screen...contain number 00000007b and 0000000f4
  • 2 more comments
  • owaiss Sep 09, 2009
    i dont doo anything...when i try to play an audio or movie..the screen will shut down and appear the problem number....cannot copy the full text number...too much
    i changed the RAM with the new one...and i also changed the hard disc drive with a new one...still cannot format the new one
    the old ram was changed with the new ram..still having the same problem
  • reg091 May 11, 2010
    Did you do anything that has caused this error (installed new hardware etc)? Can you give the full text of the error please.
  • Acer Master
  • 4,924 Answers
Check the ram memory ...and after remove and put it back in ...with care ...remove the bios battery to restore optimal defaults ...also try to format ntfs quick ..cause if the hard drive has some issues it will block during the normal installing ..but ussualy those 00000000 on blue screen are from ram memory issues...
Posted on Sep 09, 2009
  • Catalin Turcu
    Catalin Turcu Sep 09, 2009
    hmm this not sounds right ...may just that be the problem ...cause teh ram incompatibility is the first in blue screen errors...check teh freq. on ram and the way hdd is attached...it get to work ... see that the CPU is not temperature limited ...
Blue screen appear while formating..
Could you not format your computer? Usually, when formatting with XP blue screen appears for a few minutes and then it continues formatting. But if it is not your problem, try formatting your system again with another OS.
Dec 22, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
Blue screen
The blue Windows error - or "blue screen of death" as it is sometimes called - is what's known as a fatal error for your system. There are a number of blue screen errors which appear at various times on your system, but they all have the same thing in common..
I think you can try regtool and fix BSOD.
http://www.keep-pc-clean.com/
May 03, 2010 | Toshiba REGZA 47HL167 TV
Giving blue screen with error message & getting stucked.
the blue screen also appears when there is a hardware malfunction. use ur BIOS to check whether all ur hardware are working fine
Feb 12, 2010 | Dell Inspiron 6400 Notebook
0x0000000A(0xf000ef73,0x0000000Z,0x0000000,0x8081E66A) i cant format my pc in middle of my installation of my new OS? error appear blue color background
The blue background with the error message is called the blue screen of death (BSOD). Normally it means bad ram or hard drive, but here is a link for more info. Hope it helps.....Hank
http://support.microsoft.com/?kbid=314063
Nov 14, 2009 | Computers & Internet
System is blue screening giving an error meaasge ....registry file corrupt. error 0000146. I am told there may be a hardrive crash...can it be repaired??
yes.
At the Windows XP Recovery Console command prompt (C:WINDOWS>), perform the following steps:
  1. Type the following command:
    cd
    There must be one space between cd and .
  2. Press the <Enter> key to display a C:> prompt.
  3. Type the following command:
    cd system~1_resto~1
    Note the underscore character after the backslash.
10675121.gif NOTE: An Access is denied message may appear. If so, follow the steps below:
    cd windowssystem32config
  2. Press the <Enter> key.
    ren system system.bck
  4. Press the <Enter> key.
  5. Type the following command:
    exit
  6. Press the <Enter> key.
    The system will restart.
  7. Begin again with the first step under Boot the Computer from the Windows XP CD and Start the Recovery Console.
    dir
    Among other information, the dir command will list one or more directories, such as RP1, RP2, and RP3. These directories contain Windows XP Restore Point data.
    Make note of a recently created RP directory, but not one that was created in the past few minutes.
    cd rp<x>
    where <x> equals the restore point data directory number (i.e. RP3).
    cd snapshot
  7. For either error message containing ...CONFIGSOFTWARE:
    1. Type copy _registry_machine_software c:windowssystem32configsoftware.
    For the error message containing ...CONFIGSYSTEM:
    1. Type copy _registry_machine_system c:windowssystem32configsystem.
10675121.gif NOTE: If queried whether to replace the file, press the <Y> key and press the <Enter> key.
    exit
Oct 23, 2009 | Dell Latitude X300 Notebook
Blue screen error
Hi
Just boot in safe mode or Last Good configuration and then go to windows START button there take MY COMPUTER>>ADVANCED>>START UP AND RECOVERY>> Disable memory dump here .Your blue screen problem will be solved
Thank U
Please rate me as it wil cost u just one click
Oct 23, 2009 | Acer Aspire 4315 Notebook
Alcohol 120% problem
format your pc it.........it is the bsod error
Jul 25, 2009 | THQ Alcohol 120% (alcohol120)
Error in registry
The easy way is to make windows repair itself, this can be done by starting your pc from the windows cd, then when the blue screen appears with 3 options,
..install windows,...repaire,...quite ..F3,
press enter for installation, then F8 to accept, then windows setup will search for installed OS and then asked you to press R to repair it, from this point you can press R and wait while installer delete windows system files the reinstall them without loosing your installed programs.
Dec 10, 2008 | Computers & Internet
Blue Screen
There are several problems for which blue screen can appear:
1) Memory problem,
2) Operating system problem,
3) Application problem etc.
Generally an error code is also displayed with the blue screen. You need to tell the error number to know more about your problem
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Acer Aspire 4530-5889 Notebook PC Logo
190 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
