Question about Intel Motherboard
Hi... my system is a problem switch on 2times long beep next contniue the beep plc solve the problem
    Sniper:
  • 75 Answers
Brother your ram is not working.First eject your rams clean the rams and also ram ports then put it back.If still not working then u will have to change your rams...
Plz dont forget to rate thnx
Posted on Sep 09, 2009
Calling for heat red light flashing 2times
Hi, pull the panel off the unit where the light is flashing. If everything stops working, then you have a switch around the perimeter of the panel that killed the power and you will need to tape it down to restore power to the furnace. Once this is done, ( if it even happened ) look on the panel or the unit for a strip of paper that will be glued there telling you what each code means, and what to do to solve the problem. 2, 3, 4567 flashes mean different things going on. It may have tripped a limit switch, flame roll out switch ect. These are manual reset switches, so you will have no problem resetting them. I hope this was of help to you.
Shastalaker7
A/C, & Heating Contractor
Sep 19, 2011 | Intertherm Heating & Cooling
I'm currently wanting to completely system wipe my Toshiba Satalite L350- 203, i basically want to clear it back to default. ( as though i'd just bought it from the shop)
Hi.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
Regards.
Jul 17, 2011 | Computers & Internet
Dear all. We use twin modem V.3266 of Motorola to connect data from PLC A&B to SCADA via fiber optic cable and Mux (NEC 6000), but now two modem are usually display training status, and data don't...
Hi Mr Q,
You would need a big check-up on:
1. PLC (Comm card - Prosoft ?)
2. Modems
3. Multiplexers
4. Optical Cables
5. RS232 Cables
6. Comm Port Spliter (MOXA?)
7. SCADA System (Oracle Database ?)
Please let me know your above check-up results so I provide further help.
TBT
Oct 26, 2010 | Arris V3229 (6209526200030) Modem
With my mercury mother when I switch on my pc it
Beeps are usually a warning that the computer is having hardware issues, this is usually down to the memory being bad.
Try taking out the system memory and clean the contacts and the slots that the memory snaps into with a clean, dry, soft paintbrush, then reseat the memory and try to boot the machine up.
If it still won't boot count the number of beeps and if they are long or short and post back here.
Regards.
Aug 01, 2009 | Mercury Computers & Internet
I need instructions for my sanyo plc-sw35
Hi There,
I Have a plc-sw35, Gave me many issues (switching off etc..) Ive managed to repair it, and made the manual available. http://www.entwan.netau.net/1_8_Repair-Schematics.html
My repair story is there also.
Jul 14, 2009 | Sanyo USHIO PROJECTOR LAMP, Projector Lamp...
Sanyo plc sw30 help
i had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Nov 02, 2008 | Sanyo PLC-SW30 Multimedia Projector
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Ghosting image
Hi there
I'll bet you any money that the problem is cable related.
We often get this problem and by swopping the cables we normally get the problem solved.
Hope this is of help
Mar 26, 2008 | Sanyo PLC XU30 Multimedia Projector
Intel Motherboard Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
