Question about Ovens
Isis electric oven with gas hob
Instructions required on how to use the setting for the conventional setting & defrost function
BADBOYJAY
  • 264 Answers
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Posted on Jan 07, 2008
  • 16 Answers
SOURCE: Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Posted on Jun 01, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
I replace the C3 Capacitor on the display circuit board of a Jenn Air model #JJW9627AAW - double oven from Sears after the display got too dimm. This cost me $1.50 total verses the $200 parts cost only.
Thanks for the tip man!
Posted on Sep 20, 2009
SOURCE: AEG Oven model D98000VF - error code F8
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
Posted on May 07, 2010
SOURCE: Diplomat Softline ADP0300 Gas-just not cooking ...anything!
hi guys,
I have a Diplomat Softline ADP0100 model, but would like to know the basics of how to use it.
On the left I have a set of buttons (for closed heating , open heating with (wave signal), stir heating, temp reduce/increase button) and on the right a single knob that can ignite and has a counter upto 10.
Unfortunately, there is not a single manual on the internet, so need some basic instructions..
thanks very much,
Rick
Posted on Aug 07, 2011
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Dado
Sep 10, 2014 | Zanussi Ovens
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Do you know the power rating of a TECNIK TKC 1255/SS cooker
i believe this is a range oven so has gas hob top one large oven a one small oven main oven draws around 2.5 kw on fan and 1.8 on conventional elements.
May 17, 2010 | Ovens
Having gas eye level oven and hob fitted what distance do we need to leave between the two
All the information you require will be in the manufacturers instruction books. If you have mislaid these then contact the retailer or manufacturer for advice. It is essential you follow their recommendations to avoid errors that could be ultimately dangerous.
Sep 22, 2009 | Belling XOU252 Electric Single Oven
Jun 01, 2009 | Ovens
Oven/Hood clearance
Minimum 30" from cooking surface is general guideline, check with your installation instructions, for liability and insurance purposes, if you do not, and something happens, you may not be covered. Follow specifications
Apr 01, 2009 | Belling XOU487 Electric Double Oven
ZBS 1063 displayng
You have activated in some way the "child protection" function.
Please, check on the instruction book how to deactivate it .
Nov 17, 2007 | Zanussi ZBS963X Electric Single Oven
Ovens Logo
951 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
