Question about Toshiba E-Studio167 Copier
Paper misfeed how do i open side cover to expose stuck paper?
    Scholar:
  • 136 Answers
Very Simply
If you have a Duplexer on it their is a Latch or handle pull the Handle towards the side direction
>>>> this way then after that there is a latch near the from lift that latch in the UP direction
then the side door will open and then remove paper.
Posted on Sep 13, 2009
It says there is a misfeed
a bad sensor, cheaper to buy a new printer than to repair it
May 29, 2014 | Sharp Mx-4111n Multifunction Copier
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Have Kyocero 2050. Error - Misfeed paper - Open Left Cover and remove misfed sheet. Jam 00. I opened left-side cover and found no sheets stuck anywhere in sight. I can't find Jam 00 definition in...
I was having the same problem with the same model and same error. Then I discovered there's an extra panel you can pull out of the side - it's not the one the display is indicating, it's the one all the way on the side. When you pull on the grey level and it comes down, keep pul;ling on the grey level because ANOTHER panel comes down under that and I found some paper jammed in there. Once I removed it it worked fine.
Dec 13, 2010 | Kyocera Mita KM-2050 Printer
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Red blinking light
    Hi, this is not a cartridge related problem. As you have written, it is related to the paper misfeed. When removing any future paper misfeeds, always take extra caution as not to destroy the paper sensor. If it jammed near the paper tray area, first open the right cover to see the paper, the try to pull it slowly till it comes out. Never try to force it out as you may tear a small piece which will show you that a misfeed is still on. If it does tear, carefully remove it until its out. If it jams on the fusing unit, release the side levers on the copier or turn the green rotating lever on the front which appears when front cover is open until it ejects it out.
    If you are sure there is no jammed paper, make sure the spring on right side of fusing unit, where there is a sensor is retracted to its position. Good luck pal.
    Jun 05, 2010 | Sharp AL 1631 Copier
    I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
    Indication Cause and remedy Page
    Drum replacement
    required indicator
    Steadily
    lit
    Replacement of drum cartridge will be needed
    soon. Prepare a new cartridge. 70
    Blinking Drum cartridge must be replaced. Replace it with
    a new one. 58
    TD cartridge
    replacement
    required indicator
    Steadily
    lit
    Replacement of TD cartridge will be needed
    Blinking TD cartridge must be replaced. Replace it with a
    new one. 57
    Misfeed indicator Blinking
    A misfeed has occurred. Remove the misfed
    paper referring to the description of "MISFEED
    REMOVAL".
    63
    SPF misfeed
    indicator Blinking
    An original misfeed has occurred in the SPF.
    Remove the misfed originals referring to the
    description of "D: Misfeed in the SPF".
    67
    Power save indicator is
    steadily lit.
    The unit is in the preheat mode. Press any key to
    cancel the preheat mode. 54
    The unit is in the auto power shut-off mode.
    Press the start ( ) key to cancel the auto power
    shut-off mode.
    54
    The paper tray indicator is
    blinking.
    The paper tray is not installed properly. Push the
    tray into the unit securely. –
    "CH" is blinking in the
    display.
    The TD cartridge is not installed. Check if the
    cartridge is installed. 57
    "CH" is steadily lit in the
    display.
    Side cover is open. Close the side cover
    securely by pressing the round projections near
    the side cover open button.
    "P" is blinking in the display.
    The paper tray or multi-bypass tray is empty.
    Load paper. 15, 17
    A misfeed has occurred in the paper tray or
    multi-bypass tray. Remove the misfed paper. 63
    A letter and a number appear
    alternately.
    The scan head locking switch is locked. Unlock
    the scan head locking switch. 9
    alternately.
    The unit will not function. Turn the power switch
    off, remove the power cord from the outlet, and
    contact our Technical Assistance Department at
    1-(630)378-3590 in the USA or 905-568-7140 in
    Canada.
    May 13, 2009 | Sharp Office Equipment & Supplies
    Misfeed on lanier 7320
    Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
    in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
    Apr 23, 2008 | Lanier 1205 Copier
    Minolta Di520 false misfeed
    Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
    Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
    Lanier lp126cn
    I would need more information for this fault. Your "question" is very criptic.
    Are you getting a paperjam error, or is the machine not picking up the recording paper or the document feed?
    Did you have a paper jam and clear it, but not all of the paper came out? If so, unplug the machine and open the upper cover. On the right you should see the print head under the top cover (you may need a light). See if you can grab the head and move it. If you can move it then it's not locked. This usually means the machine has a clump of wadded up paper stuck in it somewhere. This paper is usually on the right side between the head and the outer case. You might be able to see it if you shine a flashlight in the area where the head goes AFTER MOVING THE HEAD to the left. If you can see paper in the head maintenance area, you'll need tweezers or something to pull it out. If you can't see anything on the right side, look in the same area but on the left side. If you do see paper on the left side, be careful not to damage the encoding wheel while you're trying to remove the paper.
    If this doesn't help, please provide more information.
    Dec 21, 2007 | Brother MFC 420CN All-In-One InkJet...
    Toshiba E-Studio167 Copier Logo
    118 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
