Question about Electronics - Others
I have a Portawattz /Power pac 300 watts, Serial # 20834197. I am in need of a wall plug charger for the above unit.Am unable to locate one that will fit this unit. Please let me know ASAP. David. dhbedw@yahoo.com
SOURCE: need to replace wall charger for portable dvd -PDV-702
Well, you could bring it in to radio shack and have them check what type of tip you need, and then just buy a universal charger with that tip included.
Posted on Jul 27, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Power Supply Bestec ATX-300-12EB3- Rev: s4(S) 300-watts
yes if you can get the side plates unscrewed and the backplate plate uncrewed then the sides should lift off of the power supply now if you look at the board where all of the wires are it should be on the side by the power cord they are pretty small and some of them are soldered in so be carefull ok keep me posted ook best regards mike
Posted on Aug 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Fuse location on wall mounted Whirlpool MH7140XFQ
The fuse is in a holder located behind the control panel assembly.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, you can download it here.
If the oven is dead, it may also be a bad magnetron thermostat or oven cavity thermostat.
The first one can probably be accessed through the opening behind the control panel, but the oven cavity thermostat cam only be accessed by removing the oven from the wall, then removing the outer cover.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 23, 2008
SOURCE: I need serial number of nero 9.2.6
ineed serial number of nero 9.2.6 freeware
Posted on Feb 15, 2009
  • 26 Answers
SOURCE: spot light is unable to recharge with the wall
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Posted on Oct 22, 2009
So i lose my Literati charger right after my birthday! I cant find it anywhere and i found my old t mobile charger and it fits perfectly. But i cant tell if its chargeing and it wont turn on! Please help...
Stop!
There are no voltage and amperage "standards" for low voltage connectors found on devices made to run from an external "wall wart" or transformer type charger or adapter. Just because a connector "fits" does not mean the power is 1) the correct voltage 2) correct polarity 3) correct type (AC or DC) or 4) can supply the amount of power needed to operate the device.
You may have done irreversible damage to your device by literally "grabbing any old charger that fits" to power it. Obtain the correct charger - or if unable to find one; determine the characteristics needed by the device - those variables are listed in 1 through 4 above.
You may find adjustable power sources that allow 1) changing of tips to fit the device, 2) a selector to choose from a range of voltages, 3) a switch to select AC or DC output and 4) the ability to plug in the tip backwards so that the polarity reverses. The last thing needed, is to know how much current in amps or power in watts is needed by the device. The charger / adapter should be chosen on its ability to supply this power continuously - never choose a charger / adapter that provides less than any of the electrical requirements; otherwise damage to the charger or device may occur - and if left unattended, could overheat and cause a fire.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Computers & Internet
I just got a Marlboro Power Pack too and have not idea how to charge it. It came with a corn with a cigarette lighter plug at one end and a negative and positive plug at the other end. what does this...
The pac will have a door on both sides that hide the cables you hook to a battery to help jump start a car once it is charged up. The cord that you say has a cig plug on one end is used to charge it using your car plug. There is another door on the back of the Pac that holds all the accessories, extra fuses and the charging cords. It does not sound like you have the A/C adaptor to plug it into a wall outlet.. If this unit is old the internal battery may be bad these Pac's are notorious for battery failure. You can find these batterys on eBay for about $13.
Nov 12, 2010 | Garden
My 1000 watt inverter has stop from supplying AC power
Unless the set is checked into , it cannot be confirmed if the fault is due to :
Failure of the switching semiconductors- drivers- Mosfets
Failure of the transformer
Failure of the switching frequency generator-IC
Failure of the in voltage detect or relays.
Oct 11, 2010 | Statpower PORTAWATTZ 1000 Watt Power...
Timer will not tirun on the lights, it stops when it gets to the time to turn on.
Malibu home page
Malibu manuals
Try the manual override >>> un-plug power pack and try loosening manual override with WD-40
It sounds like the clock motor is unable to push the manual override
Don't continue to run power pack or the clock motor will burn up or break a plastic gear
If manual override will not work, or clock will not trip on lights, you need a new power pack
Power pack size chart and wire length
Be sure to buy same wattage power pack as you have
The 300 Watt unit is made for 15 - 20watt bulbs (15 x 20 = 300)
If you buy 600 Watt power pack and hook it up to 10 - 20 watt bulbs, it will burn out the bulbs
Manual also says to replace burned out bulbs ASAP or other bulbs will burn out.
Oct 09, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
I need a data for the Astec SA302-3515 300-Watt Power Supply?
Everything you need to know can be found here:
http://www.atxpowersupplies.com/300-watt-power-supply-fsp-atx-300-gu.php
(just copy and past the above link in your internet address bar in a new tab)
Mar 31, 2010 | Astec SA302-3515 (6500165) 300-Watt Power...
Power supply in watts
you can try a Power supply unit with 600watts
Mar 29, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I have a Bestec atx-300-12az and i need to know which power supply harness to use on a Samsung model#HD103UJ hard drive.Thanks,Tony
Technical Details
  • Samsung Spinpoint HD103UJ 1 Terabyte SATA/300 Hard Drive General Features:
  • 1 Terabyte formatted capacity 7200 RPM spindle speed SATA/300 interface 32 MB buffer
  • 8.9 ms average seek time 4.17 ms average latency 3.5-inch form factor
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
SATA Power3 Peripheral4 Floppy5 02 +3.3V (Orange)
03 COM (Black)
04 +5V (Red)
05 COM (Black)
06 +5V (Red)
07 COM (Black)
08 PG (Gray)
09 +5VSB (Purple)
10 +12V (White)
11 +12V (White)
12 +3.3V (Orange)
13 +3.3V (Orange)
14 -12V (Blue)
15 COM (Black)
16 PS-ON (Green)
17 COM (Black)
18 COM (Black)
19 COM (Black)
20 Blank
21 +5V (Red)
22 +5V (Red)
23 +5V (Red)
24 COM (Black)', CAPTION, 'Pin Signal (Color)', WIDTH, 150, BGCOLOR, '#000000', FGCOLOR, '#FFFFFF');" onmouseout="return nd();" href="javascript:void(0);">matx24pin.gif
atx12v.gif sata.gif drive.gif floppy.gif This ATX12V power supply is a 300W, five output unit with remote on/off, and UL, CSA, and TUV approvals. RoHS compliant. Original HP part number 5188-2625 used in many Media Center, Pavilion, and Presario computers. Also serves as upgrade for HP/Compaq part numbers 5189-3964, 5188-0131, 5187-5116, 5187-6114, 5188-0129, and 410507-001. Airflow drawn out of case into surroundings by 80mm internal fan. Built-in power status LED above AC inlent. 2 x 12 (24 pin) main board power connector. Includes two daisy chained Serial ATA connectors. Bestec model ATX-300-12Z CDR, also replaces ATX-300-12Z BC, ATX-300-12Z BD, and ATX-300-12Z CC. i trust this helps
Jul 15, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Electronics - Others Logo
302 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
