Question about Watches
Where can I find Casio Watch spare parts? My watch is a Casio dw6800 and has a defective water seal rubber ring. I only need to replace this part but I can't find anywhere selling this.
  • 4 Answers
How can i get water out between 2 glasses on casio pro trek 2894
Hi Dirk
Bad one having water inside your Protrek or any watch for that matter-mechanical or electronic.
It means one of your seals has failed most likely the back one.
Look carefully at the back seal, if you squeeze the back plate, and the main case between your thumb and index finger you may notice a slight movement (use x10 magnification) That microscopic gap is enough to flood your watch and the deeper you use it the bigger the flood. The problem is the case, it is made of cheap nasty plastic and over time it deforms and the rubber seal contracts. Any slight over tightening of the screws, pulls the plastic thread out and stops the back plate making a good seal between the back plate and the rubber seal in the groove of the main case. For the price one would be excused for expecting that these Casio watches had a better quality case, even better a screw on back plate (like a proper 100m depth watch) rather than the individual 4 screws at each corner and a prayer. There are ways of fixing the screw threads but it never lasts....
To get the moisture out, just remove the backplate and discard the batteries. The sooner this is done the better the chances of success. Leave the watch open, face down in a warm place, preferably loosely covered by a glass bowl to stop dirt getting inside. After few hours check if the water is gone. If on inspection of all the contacts they do not exhibit any rust or white chalky deposits. Replace the new batteries and reset the watch by shortening the reset pins. If all seems ok and you have a proper display and all funtions works. You may purchase a new seal from Casio or simply clean the existing one with a little blu-tak to remove the dirt and run A LITTLE!! bead of vaseline along the rubber top to aid the seal.
I will not use the watch under water anymore and chances are that it will be downhill for the watch from now on, sorry.
I hope this helps
Jan 25, 2017 | Casio Watches
Casio Wave Ceptor 2296 watch battery replacement
if it's a water proof watch or water resistant then yes it might use pressure instead of an O-Ring to seal the watch from letting water inside of it. And if thats the case the watch let water in like a sponge in the current state it is in. If i were you and the watch was that important to me, i would take and send it in. Watch battery's need replacing what every 5-8 years? Over that amount of time the price really isn't too steep.
Feb 02, 2008 | Watches
Where can I buy a replacement wristband for my casio twin resist TRT101H-1AV. Please i need someone to help me, i've searched everywhere for it, it was a present from'my mom,the band tore
Try support at the Casio website...eg for spares
http://www.casio.com/support/buyparts
(two outlets, one in CA one in NJ, emailis prob best depending on your location within US. If not in US you will need to try Ca eg sio website for that particular country.)
You could try downloading a manual to see what that says if you haven't already got one This webpage
Timepieces Watches Manuals CASIO
shows you how to do it (you need to get the 4 digit code from the back of your watch and type it into the box).
Some watches are made with the strap as an integral part of the watch and so in the proper sense cannot be replaced with a spare, the manual might tell you about this.
Failing all else you might try ebay or other such site where I have found casio watch straps for sale.eg (but not for your particular watch)
Genuine Factory Casio 25 16mm Black Twin Resin Replacement Watch Band...
18.April.2015
Apr 17, 2015 | Casio Mens Twin Resist watch TRT-100H-2AVH
I need O-ring seal for CASIO 1346 water resistant (from year 2001). Where I can bought it please?
Bring it to a watch repairman, or into a watches/jewelery store to order it.
You also can try to order online through Casio website (Many watch company's websites only sell replacement parts through watches/jewelery stores or repairmen, not to individual.)
Feb 19, 2011 | Casio Watches
My Casio watch band has split apart where the rubber part holds the main pin to the steel watch band making the band unable to be repaired. I would like to find a replacement watch band.Can you help me?
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Oct 26, 2010 | Casio G-Shock MTG900DA-8V Wrist Watch
Battery replacement
Hi.
Battery replacement is done removing the back plate. The back plate is uncrewed clasping it with a special tools and rotating anti-clockwise. In absence of the special tool a common pair of tweezers will do the job.
Once the back plate is off, extreme care must be taken with the rubber seal, running around the edge of the case opening. This is very delicate, and damaging or kinking the seal may result in the watch loosing its water proof capacity. For this reason battery replacement is better done at the shop.
Here casio page for this model:AMW320R-
Sep 28, 2010 | Casio AMW320R 1EV Casual Sports Watch
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
How water resistent is watch??? Anyone with experience?? How about after battery replacement?
mcdevito 75 here, Usually 50--100 meters of water resistance on brand new watches. However after a battery change, unless you also change the gasket (rubber ring) on the cover, you could loose all water resistance capability.
May 28, 2010 | Casio AWS90D-2AV Wrist Watch
What do you use to snap on the back plate of a wristwatch
Tools are available from many watch suppliers, one is Jules Borel, jborel.com, best to get a new gasket and mabey a spare if you wear this in the water then a new crown or crown seal also.
Jun 11, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Watches Logo
1,334 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
