Question about Microsoft Windows XP Professional SP2 for PC
Internet not connecting
My internet not connecting..as my network adapters got yellow marked... cant access internet... plz let me know the sollution as soon as possible... thank you
  • 103 Answers
There is possibility that there is duplicate address exists on network according to your network adapter. So you have to change or renew the IP address in TCP/IP setting of network adapter
Posted on Sep 09, 2009
  • Ghulam Miran
    Ghulam Miran Sep 09, 2009
  • 1,272 Answers
Update the drivers for the network adapters. You may also run recovery cd if you have for those computers.
Device\NTPNP_PCI0027
Troubleshooting :
Cannot access internet in OS using onboard network card bg-country_outline_top.png bg-country_outline_bottom.png Solution
1. Please check the LAN settings in BIOS.
2. Install a fresh OS and the motherboard driver, network card driver in support CD or downloaded from official website.
3. If the network card is not recognized in Device Manager, please contact reseller (service center) for tests.
4. If the network card is recognized in Device Manager, please do some troubleshooting as the following steps:
4.1. If there is yellow question mark or exclamation mark before the network card, please re-install OS and drivers. If the problem persists, please contact reseller (service center) for tests.
4.2. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection, the network cable is shown as "un-plugged(X)", please check network cable/router/switch/modem/other network peripherals and network port, or plug network cable to other system for test. If the problem persists, use another computer in the same network environment to check if it can access internet. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable.
4.3. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is disabled (grey), please enable(right click and choose "Enable") it for a test. If the problem persists, please turn off firewall, search and kill virus, reinstall OS and drivers. If the problem still exists, please contact reseller (service center) for tests.
4.4. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is shown as "Limited or no connectivity" (yellow exclamation mark)", please do some troubleshooting as the following steps:
4.4.1. Right click and choose "repair"
4.4.2. Unplug and re-plug the network cable
4.4.3. Re-connect the network or access IP
4.4.4. Restart
4.4.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.4.6. Skip router and connected to Modem directly
4.4.7. Turn off other computers in the same network to avoid IP conflict
4.5. If there is no yellow question mark or exclamation mark before the network card, and there is no abnormal situation in Control Panel/Network Connections/Local Area Connection, please do some troubleshooting as the following steps:
4.5.1. Try to access IP or Static IP automatically
4.5.2. Unplug and re-plug the network cable
4.5.3. Re-connect the network or access IP
4.5.4. Restart
4.5.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.5.6. Turn off firewall, search and kill the virus, reinstall OS and drivers
4.5.7. Check MAC address ( You could follow the commands: " Start"-" All Programs"-" Run", please input " cmd", after that you could input " ipconfig/all" to check MAC address)
4.5.8. If possible, use another computer in the same network environment to check if it can access internet
a. If the network connection is OK in another system, please contact reseller (service center) for tests
b. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable
Mar 03, 2014 | ASUS SABERTOOTH Z77 LGA1155/ IntelZ77/...
TP-LINK TL-WN321G - Hi-Speed USB - 802.11g driver not install in window xp
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"
Apr 03, 2013 | TP-LINK TL-WN321G - Network adapter -...
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Unable to conect to internet this is on going problem
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
or you could click start control panel admiistation tools computer management device manager look for network adapters it might have a red X or yellow question exclamation ? ! mark if you see either of these right click to update driver if your computer came with a motherboard disk the drivers could be on it
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jul 21, 2011 | Computers & Internet
I cannot get internet explorer 7 back on why. Thanks.
if you have upgraded to newer internet explorer you might not be permitted to revert back to a lesser due compatability programs that need a higher level of internet explorer to run
if you mean you cant get an internet connection
hope this helps
Jun 28, 2011 | Computers & Internet
Cannot connect
if you are refering to your internet connection
hope this helps
Jun 22, 2011 | Computers & Internet
Cannot connect to the internet
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
Jun 20, 2011 | Computers & Internet
One computer will not connect to the internet
Possible the network card on the computer. Open the control panel on the not working vista pc. Make sure you are in classic view and select device manager. Check to see if there are any yellow exclamation marks, or question marks on the icon beside your network adapters: ethernet adapter or pci controller, this would indicate conflict on the computer. You will either need to reinstall that specific adapter for a disk or usb stick, or contact your pc vendor to repair it.
If the icon beside has a small white circle with a block arrow on it, this adapter has been disabled. Right click on it and select enable to start the connection again.
If this is no help try temporaly disabling your firewall it could be blocking your router connections.
Apr 16, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot connet ot interner
check the driver of your network controller, go to device manager, to access this, right click my computer then click device manager tab then find network controller then click + sign preceeding of that. if you notice that there is yellow question mark of the network, you need to install driver so that you cant connect to internet
Oct 12, 2009 | Computers & Internet
Network adapter
your adapter driver is not installed plz install it
Aug 13, 2008 | Computers & Internet
Microsoft Windows XP Professional SP2 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
