Question about Whirlpool Electronic Window Air Conditioner ACQ158XR
Fan or capacitor?
When I turn on my Whirlpool ACQ088MRO window air conditioning unit, the fan does not start and I hear a low-pitched "groaning" noise. Is it probable that the fan motor is bad, or is there possibly a startup cap that might not be sending enough juice to kick it over? Any and all help appreciated. . . .
  • wj1955 May 05, 2008
    window unet fan moter bad where can I find a replacement ?
  • 80 Answers
99% BAD MOTOR BUT LAST EFFORT YOUR MOTOR HAS TWO SETS OF INTERNAL WINDINGS A START AND RUN IT SOUNDS LIKE YOUR SART WINDING MAY BE THE BAD ONE. TURN POWER OFF THEN SPIN FAN IN BOLTH DIRECTIONS A COUPLE TIMES WITH YOUR HAND TURN POWER BACK ON AND THEN IF IT DOSENT SART SPINNING BY ITSELF TRY TO SPIN IT WITH YOUR FINGERS AND SEE IF IT TAKES OFF. IF IT TAKES OFF AFTER YOU SPIN IT YOU CAN PUT A HARD START KIT ON IT AND IT WILL BE OK.
Posted on Jan 09, 2008
    Sergeant:
    Champion:
  • 362 Answers
I would say the motor is bad but to be sure test the voltage to the motor with a multimeter, you can also phisically spin the motor and if that makes it work a little not as fast and blow enough air then you know its the motor this works if you dont have a multimeter.
Posted on Dec 16, 2007
The outside unit has power going to it but isn't
maybe it has tripped off on high pressure, as you have have said the fan is not turning so will cause high pressure. now assuming the problem is the fan is not running than check the condition of the condensator /capacitor for the fan motor. if the motors winding is still good replace the capacitor and try it ON.
Aug 23, 2011 | Goodman CKL62AR61 Air Conditioner
We have one of the ACC108PS air conditioners that is not cooling right - do we need freeon - if so is it rechargeable?
Start your window air conditioner troubleshooting with checking the different modes of operation to see which components operate. Turn the unit fan to on and the cool and heat modes off. If the fan does not operate, check the power supply to the unit. Check to see if the breaker or fuse for the unit is tripped. If the breaker/fuse is tripped, check to make sure that it is the proper size circuit for the unit you have. On some units, there is a current interrupter on the power cord to the unit. Check to see if it is tripped by pushing the reset button.
If the circuit is the proper size, then you can go ahead and reset the breaker/fuse. If it trips again, then you require further troubleshooting. Shut the power off and check all of the wiring in the unit to make sure that none of the connections is loose or damaged.
If the fan does not operate but the fuse/breaker is not tripped, you should check the run capacitor for the fan and compressor. If the capacitor is good but the fan motor does not operate, you can check the fan switch and the fan motor. Ensure that the fan blades spin freely.
If the fan motor operates but the compressor does not start, change the capacitor but first you should feel the compressor with your hand. If it is very hot, then you should allow it to cool.
Then, you should attempt to start the unit in the cooling mode. As you do so, listen for a clicking sound which is an indication that it is attempting to start. If the compressor starts but does not cool properly, the unit may be low on refrigerant.
If the compressor attempts to start but shuts off very quickly, the compressor could be bad. You could try installing a "Hard Start"
If the compressor does not attempt to start, ensure that the thermostat is set below room temperature. On units with a mechanical control, you will hear a click when you adjust the temperature. That is an indication that the thermostat is working properly.
Jul 12, 2011 | Whirlpool ACC108PS Air Conditioner
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
Running but no cool air blowing
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems
Jun 15, 2011 | Weather King 10AJA3601AH Air Conditioner
Unit runs for about 5 min the cuts off. whats the problem?
Hi!!
It could be many things, the most common are Low R22 refrigerant, bad fan motor, bad compressor. obstructed condenser coil, bad starting relay, bad capacitor. among other things.
To check fan motor, set unit to HI Fan Only setting and let it run for a while, check that fan did not loose speed and it is not getting too hot.
If fan is OK, then turn unit to HI Cool 60-65 degrees and see what happens. Hear if compressor kicked in or if just made a humming noise and stopped. if this happens, replace capacitor.
Keep me posted!! Rate this post!!
Aug 14, 2010 | Kenmore 72055 Air Conditioner
Compressor will not start but the fan runs on RV air condition unit Mod 7332B896 Coleman
If you can hear compressor try to start, then kick out, then I'd say capacitor needs replace, but if you don't hear anything (moan or groan) from compressor, then I'd be looking at a new relay, or at least testing it.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Fan motor in window ac/heat unit turns slow or not at all
Did you change the capacitor when you changed the fan? If you didn't you need to. And that capacitor is a dual one running the compressor and fan. So make a diagram of it what wires go where the area is real tight and some wires are the same color. You might make labels to be a little easier. Also get the same size capacitor when you change it.
Jan 16, 2009 | Whirlpool Electronic Window Air...
WHIRLPOOL ACQ088MRO
Take what covers off you can to see if you can look at the fan wheel. With the power disconnected, make sure that the wheel spins freely. Sometimes stuff gets in there and blocks the wheel. Hope that helps. From there it goes to checking controls and other functions of the unit that may require Whirlpool service.
Jun 10, 2008 | Whirlpool Electronic Window Air...
Low pitched grinding or groaning noise
Dan i recently had one of these in the shop and discovered a problems with blown capicitors in power supply.. however the low pitch groan indicates a fan or what is known as a color wheel. if this motorized part does not reach speed the lamp will not fire. replaceing the color wheel is not an easy task.
Dec 24, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Whirlpool Electronic Window Air Conditioner ACQ158XR Logo
424 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
