Question about Smeg SE250XUK Stainless Steel Electric Single Oven
Oven heats up and doesn''t stop heating
When I turn on the oven it heats up and the orange light is lit. The light never goes off but the oven keeps heating up.
SOURCE: zanussi zbf 760 (9 yrs old now)
make sure the thermostat probe is fully into the oven
Posted on Nov 19, 2007
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
hongster
  • 6 Answers
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Jul 25, 2014 | Lincoln Impinger Electric Countertop Oven...
Hoover bottom oven not heating up
Hoover Oven not heating? How to replace a Hoover fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2012 | Ovens
Westinghouse 662 oven doesn't totally turn off,
We have had the same issue, it drove me crazy.... Ours has just stopped working altogether now.
Sep 13, 2011 | Ovens
My oven will not heat up. the orange light turns on but thats all.
I am assuming this is an electric oven? If you have an ohm meter you can verify that the bake or broil element is good by measuring the resistance across the element. If it reads short then the elements are bad. The more expensive problem which usually tends to be the case is the oven controller board. There are to relays that control the high voltage current that is supplied to the elements. When the oven is turned on a signal from the oven controller activates the coil on the relay and closes the contact allowing current to flow to the element. There are two relays, one for broil and the other for bake. Try the oven on broil to see if that element heats up. If it does it could be the bake element, if it doesn't you till need to get a replacement oven controller board. They usually call them timer modules or clock modules. Good luck!
Jul 20, 2011 | Kenmore Ovens
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
My oven is taking 30 min to heat up to 350 degrees. the light sensor is turning orange what might the problem be??????
heatman101
May 07, 2010 | Maytag CWG3100A Gas Single Oven
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
569 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Smeg Oven Expert? Answer questions, earn points and help others
