Question about HP Photosmart C7180 All-In-One InkJet Printer
On/off switch does not function
The power supply works. Switch doe not start printer
  • 53 Answers
If the button is gone sticy so need to replace the i\o button u can verify by hearing the click sound from the start buttton
Posted on Sep 09, 2009
Error code E000002
That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine.
If the machine is receiving full power, you'll need to get rid this error through entering service mode.
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
NOTE: from this point forward you'll be in service mode which has a 60 operational second window. After 60 seconds it will exit out of this mode and you'll have to start over.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
The printer should restart and be working normally.
Feb 21, 2016 | Office Equipment & Supplies
My hedge trimmer has a faulty switch
Hi Bob:
First, make sure the power supply cord is connected with power at the tool.
Since it's already broke, you really can't hurt it so you get to play if you're into it.
Disconnect from power supply!
Try to determine if something is stopping the switch from moving far enough to function.
Dismantle until you can get the switch out. Try to clean the switch terminals and check the function with a continuity meter.
If you can't get it to work, see your local dealer about getting a replacement part.
Sep 18, 2015 | Bosch AHS 45-16 Electric Hedge Trimmer
The on and off switch does not functioning
It's usually the power supply and not the power switch that causes this particle problem. If you tell us the make and model of printer, we may be able to help.
Dec 19, 2013 | Office Equipment & Supplies
Printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Jan 15, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Printer does not switch on - power cable is functioning and plugged-in.
Your Printer doesnot switch on, your Power cable is ok and plugged in, so your first you check the switch botton is ok or not. Internal wire may be diconnect from your printer Switch botton. otherwise your power supply board problem, so you change or repair the power supply board of your Printer. You will Check these problems, you must solve your problem.
Thank U
Aug 28, 2009 | Office Equipment & Supplies
Canon PIXMA MP110 printer will not switch on
canon MP 160 printer not working while switch on, power does not glow.
RAHUL
09435030805
Jun 07, 2009 | Canon Office Equipment & Supplies
MACHINE DOES NOT SWITCH ON
You most likely have a bad low voltage power supply. They develop problems from heat in the power supply area.
You can google a business called " the parts drop". Give Britt a call and see what he has. He will give you the best price .
May 26, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Gestetner 3245 No light on screen after switch on. What has Failed?
can have some defective solder in the power supply.
Check the power supply board solder.
Oct 28, 2008 | Gestetner DSm645 Digital Imaging System
IR 2000
Fuser error probally needs fuser replaced and the reset as below
try this
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
or this is explaination of the error and required fix from service manual.
E0000000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
4. Main power supply PCB, DC controller PCB
Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Nov 18, 2007 | Office Equipment & Supplies
Push switch, no power.
It can be the power supply. Does the power supply fan work when you push the power switch ?
Jul 22, 2007 | HP Pavilion xl756 (P1358A#888) PC Desktop
HP Photosmart C7180 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
